hey mtx,
that’s what I found in BOM of Myriad RF board (in Digi-Key website)
http://www.hirose.co.jp/cataloge_hp/e57000028.pdf
There are both, male and female versions in this datasheet of FX10 connector
hey mtx,
I see what you mean. No there is no that type of drawings. KiCad is free to use and very simple. Let me know if you need help in finding a ruler.
Is there any document with a mechanical drwaing including dimensions, that indicate positions of mounting holes and FX10 connector?
What I meant was, a drawing that specifies where the FX10 connector is placed on the board, and where the mounting holes are located. From Kicad, you can probably look that up, but I am not using Kicad… There are meny mechanical drawngs about the board, but none with any dimensions.
Thanks
