we currently face a problem with the LMS7000m chip when we use Tx- and Rx- for a channel where we have a slight frequency offset (e.g. 5 kHz offset between Tx and Rx).
We can reproduce the issue with the Lime suite and a LimeSDR USB board. See the attached ini-Files for the three VCOs.
If we configure the LimeSDR with the attached ini-Files, then we see the strong influence of the RX-VCO on our Tx-signal. Is there anything we could do to solve this issue?
Best regards,
