If it arrived like this I would suggest contacting Crowd Supply to arrange for a replacement.
I don’t think so, since LimeUtil finds it. Can you still run the self test via Lime Suite?
Note that some people have experienced issues with certain USB 3.0 chipsets, which have been resolved by using another computer / USB 3.0 interface. Seems USB 3.0 can be tricky like this.
I cannot Initiate the LimeSDR anymore, so I cannot run the test.
This was before running the LimeUtil --update
: USB disconnect, device number 4
: new high-speed USB device number 5 using ehci-pci
: New USB device found, idVendor=1d50, idProduct=6108
: New USB device strings: Mfr=1, Product=2, SerialNumber=3
: Product: LimeSDR-USB
: Manufacturer: Myriad-RF
SerialNumber: 0009060B0046210F
This is after the LimeUtil --update failed.
: new high-speed USB device number 3 using xhci_hcd
: New USB device found, idVendor=04b4, idProduct=00f3
: Product: WestBridge
: Manufacturer: Cypress
: SerialNumber: 0000000004BE
@Psynosaur closes to ic is better for rf filtering depends on value of the cap but mostly its .01 uf for filtering rf just to minimize the noise on the equipment if not so military or medical type equipment i will not pass at the quality control off course .
You don’t need a pad as it is connected to a ground plane on the busted off side. Just scratch some of the masking around the pad to expose some copper. Bigger the blob the better the job!
@KBBF5 Hah hah, what a man Thanks, I am still awaiting response from crowd supply with regards to the RX1_W port being modified and not RX1_L as specified, for Easyfix 1.
I had to put in a spare USB 3 PCI-E(Vantec UGT-PC341) I had lying around, the USB3’s on my Asus Rampage IV extreme seem to be outdated in Linux to connect properly …
These connect first time and run at full 61.44MSPS without packet losses B-)
Does anyone have the correct location of the windows 10 drivers. I have followed the links on this thread and the official install instructions and I am not able to get the device recognized in windows 10. I see in in the device manager under usb devices as limesdr-usb
but cannot get it to come up under usb controllers as the documentation says.
also the drives I found list
limeSDR-USB (libusbK) a few times
LimeSDR-USB (libwdi) a few times
and
LimeSDR-USB version: 6.1.7600.16385 (2/10/2017)
none of them say usb3
heya did you install PothoSDR development environment?
“LimeSuite is bundled with the PothoSDR development environment to use supported hardware in an ecosystem of SDR applications like GQRX, Pothos, CubicSDR, and GNU Radio.”
I havent installed it on Win10 yet, Linux seemd easiest…
I will give it a wirl tomorrow and report back.
SDR-Console has been my favourite app for my airspy so far in Windows and it has lime support.
