Hello everyone,
i am running my LIMESDR-USB as my eNB(RAN) using openairinterface, it is getting attached to LTE-core but when i am trying to search a network on my mobile using regular(vodafone) sim card, i am not able to find the network. could anyone suggest me the reason behind this?
below is the log given.
[CONFIG] get parameters from libconfig limesdr.conf , debug flags: 0x00000000
[CONFIG] function config_libconfig_init returned 0
[CONFIG] config module libconfig loaded
[LIBCONFIG] config: 1/1 parameters successfully set, (1 to default value)
/dev/cpu_dma_latency set to 0us
[LIBCONFIG] log_config: 3/3 parameters successfully set, (1 to default value)
[LIBCONFIG] log_config: 52/52 parameters successfully set, (46 to default value)
[LIBCONFIG] log_config: 52/52 parameters successfully set, (52 to default value)
[LIBCONFIG] log_config: 15/15 parameters successfully set, (15 to default value)
log init done
Reading in command-line options
[LIBCONFIG] (root): 22/22 parameters successfully set, (18 to default value)
[LIBCONFIG] (root): 5/5 parameters successfully set, (4 to default value)
Getting ENBSParams
[LIBCONFIG] (root): 3/3 parameters successfully set, (1 to default value)
[LIBCONFIG] THREAD_STRUCT.[0]: 2/2 parameters successfully set, (0 to default value)
[CONFIG] parallel_conf is set to 0
[CONFIG] worker_conf is set to 1
Configuration: nb_rrc_inst 1, nb_L1_inst 1, nb_ru 1
[LIBCONFIG] loader: 2/2 parameters successfully set, (2 to default value)
[LIBCONFIG] loader.NB_IoT: 2/2 parameters successfully set, (1 to default value)
nb_nbiot_rrc_inst 0, nb_nbiot_L1_inst 0, nb_nbiot_macrlc_inst 0
[LIBCONFIG] TTracer: 4/4 parameters successfully set, (4 to default value)
configuring for RAU/RRU
CPU Freq is 3.603005
ITTI init, useMME: 1
e[0m[TMR] Starting itti queue: TASK_UNKNOWN as task 0
e[0me[0m[TMR] Starting itti queue: TASK_TIMER as task 1
e[0me[0m[TMR] Starting itti queue: TASK_L2L1 as task 2
e[0me[0m[TMR] Starting itti queue: TASK_BM as task 3
e[0me[0m[TMR] Starting itti queue: TASK_PHY_ENB as task 4
e[0me[0m[TMR] Starting itti queue: TASK_MAC_ENB as task 5
e[0me[0m[TMR] Starting itti queue: TASK_RLC_ENB as task 6
e[0me[0m[TMR] Starting itti queue: TASK_RRC_ENB_NB_IoT as task 7
e[0me[0m[TMR] Starting itti queue: TASK_PDCP_ENB as task 8
e[0me[0m[TMR] Starting itti queue: TASK_DATA_FORWARDING as task 9
e[0me[0m[TMR] Starting itti queue: TASK_END_MARKER as task 10
e[0me[0m[TMR] Starting itti queue: TASK_RRC_ENB as task 11
e[0me[0m[TMR] Starting itti queue: TASK_RRC_GNB as task 12
e[0me[0m[TMR] Starting itti queue: TASK_RAL_ENB as task 13
e[0me[0m[TMR] Starting itti queue: TASK_S1AP as task 14
e[0me[0m[TMR] Starting itti queue: TASK_X2AP as task 15
e[0me[0m[TMR] Starting itti queue: TASK_M2AP_ENB as task 16
e[0me[0m[TMR] Starting itti queue: TASK_M2AP_MCE as task 17
e[0me[0m[TMR] Starting itti queue: TASK_M3AP as task 18
e[0me[0m[TMR] Starting itti queue: TASK_M3AP_MME as task 19
e[0me[0m[TMR] Starting itti queue: TASK_M3AP_MCE as task 20
e[0me[0m[TMR] Starting itti queue: TASK_SCTP as task 21
e[0me[0m[TMR] Starting itti queue: TASK_ENB_APP as task 22
e[0me[0m[TMR] Starting itti queue: TASK_GNB_APP as task 23
e[0me[0m[TMR] Starting itti queue: TASK_MCE_APP as task 24
e[0me[0m[TMR] Starting itti queue: TASK_MME_APP as task 25
e[0me[0m[TMR] Starting itti queue: TASK_FLEXRAN_AGENT as task 26
e[0me[0m[TMR] Starting itti queue: TASK_PHY_UE as task 27
e[0me[0m[TMR] Starting itti queue: TASK_MAC_UE as task 28
e[0me[0m[TMR] Starting itti queue: TASK_RLC_UE as task 29
e[0me[0m[TMR] Starting itti queue: TASK_PDCP_UE as task 30
e[0me[0m[TMR] Starting itti queue: TASK_RRC_UE as task 31
e[0me[0m[TMR] Starting itti queue: TASK_NAS_UE as task 32
e[0me[0m[TMR] Starting itti queue: TASK_RAL_UE as task 33
e[0me[0m[TMR] Starting itti queue: TASK_MSC as task 34
e[0me[0m[TMR] Starting itti queue: TASK_GTPV1_U as task 35
e[0me[0m[TMR] Starting itti queue: TASK_UDP as task 36
e[0me[0m[TMR] Starting itti queue: TASK_CU_F1 as task 37
e[0me[0m[TMR] Starting itti queue: TASK_DU_F1 as task 38
e[0m[LIBCONFIG] opt: 3/3 parameters successfully set, (3 to default value)
e[0m[OPT] OPT disabled
e[0mreported resolution = 1 ns
e[0m[HW] Version: Branch: develop Abrev. Hash: e376241a8 Date: Mon May 11 21:10:34 2020 +0200
e[0mRuntime table
e[0m[PHY] RC.eNB = 0x55e1cb965c20
e[0m[LIBCONFIG] L1s.[0]: 24/24 parameters successfully set, (22 to default value)
e[0m[PHY] RC.eNB[0] = 0x55e1cb965cd0
e[0me[0m[PHY] RC.eNB[0][0] = 0x7f074a61c010
e[0me[0m[ENB_APP] Initializing northbound interface for L1
e[0me[0m[PHY] l1_north_init_eNB() RC.nb_L1_inst:1
e[0me[0m[PHY] l1_north_init_eNB() RC.nb_L1_CC[0]:1
e[0me[0m[PHY] l1_north_init_eNB() RC.eNB[0][0] installing callbacks
e[0me[0m[PHY] read_config_and_init() RC.nb_L1_inst: 1
e[0m[LIBCONFIG] MACRLCs.[0]: 20/20 parameters successfully set, (15 to default value)
e[0m[MAC] [MAIN] Init function start:nb_macrlc_inst=1
e[0me[0m[PDCP] PDCP layer has been initialized
e[0mConfiguring local RRC for MACRLC
e[0m[ENB_APP] sched mode = default 0 [default]
e[0me[0m[MAC] read_config_and_init() RC.nb_macrlc_inst: 1
e[0m[LIBCONFIG] (root): 3/3 parameters successfully set, (1 to default value)
[LIBCONFIG] eNBs.[0]: 20/20 parameters successfully set, (11 to default value)
e[0m[RRC] Instance 0: Southbound Transport local_mac
e[0me[0m[RRC] Setting node_type to ngran_eNB
e[0m[LIBCONFIG] eNBs.[0].plmn_list.[0]: 3/3 parameters successfully set, (0 to default value)
e[0m[RRC] num component carriers 1
e[0me[0m[RRC] enb_config::RCconfig_RRC() parameter number: 0, total number of parameters: 78, ccspath: eNBs.[0].component_carriers.[0]
e[0m[LIBCONFIG] eNBs.[0].component_carriers.[0]: 78/78 parameters successfully set, (17 to default value)
phich.resource 0 (ONESIXTH), phich.duration 0 (NORMAL)
No eMBMS configuration, skipping it
[LIBCONFIG] eNBs.[0].component_carriers.[0].emtc_parameters: 88/88 parameters successfully set, (88 to default value)
No eMTC configuration, skipping it
[LIBCONFIG] eNBs.[0].component_carriers.[0].SLparameters: 39/39 parameters successfully set, (39 to default value)
No SL configuration skipping it
[LIBCONFIG] eNBs.[0].srb1_parameters: 6/6 parameters successfully set, (0 to default value)
e[0m[RRC] Node type 0
[LIBCONFIG] NETWORK_CONTROLLER: 6/6 parameters successfully set, (0 to default value)
[LIBCONFIG] RUs.[0]: 27/27 parameters successfully set, (18 to default value)
Creating RC.ru[0]:0x55e1cb9974c0
Setting function for RU 0 to eNodeB_3GPP
e[0m[PHY] number of L1 instances 1, number of RU 1, number of CPU cores 1
e[0me[0m[FLEXRAN_AGENT] FlexRAN Agent for eNB 0 is DISABLED
e[0me[0m[PDCP] pdcp init,usegtp
e[0me[0me[93m[PDCP] ENB pdcp will use tun interface for MBMS
e[0m[NETLINK]Opened socket oaitun_enm1 with fd 84
returnValue 0
returnValue 0
returnValue 0
e[0m[OIP] Interface oaitun_enm1 successfully configured, ip address 10.0.2.1, mask 255.255.255.0 broadcast address 10.0.2.255
e[0me[0m[ENB_APP] Creating ENB_APP eNB Task
[LIBCONFIG] eNBs.[0].mme_ip_address.[0]: 5/5 parameters successfully set, (0 to default value)
[LIBCONFIG] eNBs.[0].SCTP: 2/2 parameters successfully set, (0 to default value)
[LIBCONFIG] eNBs.[0].NETWORK_INTERFACES: 11/11 parameters successfully set, (2 to default value)
e[0m[GTPV1U] Configuring GTPu
[LIBCONFIG] eNBs.[0].NETWORK_INTERFACES: 3/3 parameters successfully set, (0 to default value)
e[0m[GTPV1U] Configuring GTPu address : 192.168.1.8 -> 801a8c0
e[0me[0m[ENB_APP] default drx 2
e[0me[0m[ENB_APP] [eNB 0] eNB_app_register via S1AP for instance 0
e[0m[LIBCONFIG] eNBs.[0]: 1/1 parameters successfully set, (0 to default value)
[LIBCONFIG] gNBs.[0]: 1/1 parameters successfully set, (1 to default value)
[LIBCONFIG] eNBs.[0]: 1/1 parameters successfully set, (1 to default value)
e[0m[TMR] Created Posix thread TASK_ENB_APP
e[0me[0m[RRC] Creating RRC eNB Task
e[0me[0m[RRC] Entering main loop of RRC message task
e[0me[0m[TMR] Created Posix thread TASK_RRC_ENB
e[0me[0m[SCTP] Starting SCTP layer
e[0me[0m[TMR] Created Posix thread TASK_SCTP
e[0me[0m[S1AP] Starting S1AP layer
e[0me[0m[S1AP] Registered new eNB[0] and macro eNB id 3584
e[0me[0m[S1AP] [eNB 0] check the mme registration state
e[0me[0m[SCTP] sctp_bindx SCTP_BINDX_ADD_ADDR socket bound to : 192.168.1.8
e[0me[0m[SCTP] Converted ipv4 address 192.168.1.35 to network type
e[0me[0m[SCTP] connectx assoc_id 20 in progress…, used 1 addresses
e[0me[0m[SCTP] Inserted new descriptor for sd 85 in list, nb elements 1, assoc_id 20
e[0me[0m[TMR] Created Posix thread TASK_S1AP
e[0me[0m[UDP] Initializing UDP task interface
e[0me[0m[UDP] Initializing UDP task interface: DONE
e[0me[0m[SCTP] Found data for descriptor 85
e[0me[0m[SCTP] Received notification for sd 85, type 32769
e[0me[0m[SCTP] Client association changed: 0
e[0me[0m[SCTP] ----------------------
e[0me[0m[SCTP] Peer addresses:
e[0me[0m[SCTP] - [192.168.1.35]
e[0me[0m[SCTP] SCTP Status:
e[0me[0m[SCTP] assoc id …: 20
e[0me[0m[SCTP] state …: 4
e[0me[0m[SCTP] instrms …: 2
e[0me[0m[SCTP] outstrms …: 2
e[0me[0m[SCTP] fragmentation : 1452
e[0me[0m[SCTP] pending data .: 0
e[0me[0m[SCTP] unack data …: 0
e[0me[0m[SCTP] rwnd …: 106496
e[0me[0m[SCTP] peer info :
e[0me[0m[SCTP] state …: 2
e[0me[0m[SCTP] cwnd …: 4380
e[0me[0m[SCTP] srtt …: 0
e[0me[0m[SCTP] rto …: 3000
e[0me[0m[SCTP] mtu …: 1500
e[0me[0m[SCTP] Comm up notified for sd 85, assigned assoc_id 20
e[0me[0m[SCTP] Received notification for sd 85, type 32776
e[0me[0m[S1AP] 3584 -> 00e000
e[0me[0m[SCTP] Successfully sent 48 bytes on stream 0 for assoc_id 20
e[0me[0m[SCTP] Received notification for sd 85, type 32777
e[0me[0m[TMR] Created Posix thread TASK_UDP
e[0me[0m[SCTP] [20][85] Msg of length 27 received from port 36412, on stream 0, PPID 18
e[0me[0m[S1AP] servedGUMMEIs.list.count 1
e[0me[0m[S1AP] servedPLMNs.list.count 1
e[0me[0me[1;31m[S1AP] S1AP_FIND_PROTOCOLIE_BY_ID: /home/nano/openairinterface5g/openair3/S1AP/s1ap_eNB_handlers.c 372: ie is NULL
e[0me[0m[ENB_APP] [eNB 0] Received S1AP_REGISTER_ENB_CNF: associated MME 1
e[0me[0m[GTPV1U] Initializing GTPU stack 0x55e1c9871030
e[0me[0m[GTPV1U] Tx UDP_INIT IP addr 192.168.1.8 (868)
e[0me[0m[UDP] Initializing UDP for local address 192.168.1.8 with port 2152
e[0me[0m[UDP] Inserting new descriptor for task 35, sd 86
e[0me[0m[UDP] Initializing UDP for local address 192.168.1.8 with port 2152: DONE
e[0me[0m[TMR] Created Posix thread TASK_GTPV1_U
e[0me[0m[X2AP] X2AP is disabled.
e[0me[0m[MAC] Creating MAC eNB Task
e[0me[0m[MAC] Starting main loop of MAC message task
e[0me[0m[TMR] Created Posix thread TASK_MAC_ENB
e[0me[0m[RRC] [eNB 0] Received RRC_CONFIGURATION_REQ : 0x55e1cb99eefc
e[0me[0m[RRC] [FRAME 00000][eNB][MOD 00][RNTI 0] Init…
e[0me[0m[RRC] [FRAME 00000][eNB][MOD 00][RNTI 0] Checking release
e[0me[0m[RRC] [FRAME 00000][eNB][MOD 00][RNTI 0] Rel14 RRC detected, MBMS flag 0
e[0me[0m[RRC] [eNB 0] Node type 0
e[0me[0m[RRC] configuration->schedulingInfoSIB1_BR_r13[CC_id] 0
e[0me[0m[RRC] Configuring MIB (N_RB_DL 50,phich_Resource 0,phich_Duration 0)
e[0me[0m[RRC] [MIB] systemBandwidth 3, phich_duration 0, phich_resource 0, sfn 0
e[0me[0m[RRC] [MIB] schedulingInfoSIB1 0
e[0me[0m[RRC] [eNB 0] Configuration SIB2/3, eMBMS = 0
e[0me[0m[RRC] do_SIB23, size 38
e[0me[0m[MAC] Configuring MIB for instance 0, CCid 0 : (band 7,N_RB_DL 50,Nid_cell 0,p 1,DL freq 2685000000,phich_config.resource 0, phich_config.duration 0)
e[0me[0m[MAC] config_mib() NFAPI_CONFIG_REQUEST(num_tlv:16) DL_BW:50 UL_BW:50 Ncp 0,p_eNB 1,earfcn 3400,band 7,phich_resource 0 phich_duration 0 phich_power_offset 6000 PSS 6000 SSS 6000 PCI 0 PBCH repetition 0
e[0me[0m[MAC] [CONFIG]SIB2/3 Contents (partial)
e[0me[0m[MAC] [CONFIG]pusch_config_common.n_SB = 1
e[0me[0m[MAC] [CONFIG]pusch_config_common.hoppingMode = 0
e[0me[0m[MAC] [CONFIG]pusch_config_common.pusch_HoppingOffset = 0
e[0me[0m[MAC] [CONFIG]pusch_config_common.enable64QAM = 0
e[0me[0m[MAC] [CONFIG]pusch_config_common.groupHoppingEnabled = 1
e[0me[0m[MAC] [CONFIG]pusch_config_common.groupAssignmentPUSCH = 0
e[0me[0m[MAC] [CONFIG]pusch_config_common.sequenceHoppingEnabled = 0
e[0me[0m[MAC] [CONFIG]pusch_config_common.cyclicShift = 1
e[0me[0m[PHY] Configuring MIB for instance 0, CCid 0 : (band 7,N_RB_DL 50, N_RB_UL 50, Nid_cell 0,eNB_tx_antenna_ports 1,Ncp 0,DL freq 3400,phich_config.resource 0, phich_config.duration 0)
e[0me[0m[PHY] Initializing frame parms for N_RB_DL 50, Ncp 0, osf 1
e[0me[0m[PHY] lte_parms.c: Setting N_RB_DL to 50, ofdm_symbol_size 1024
e[0m[LIBCONFIG] loader.coding: 2/2 parameters successfully set, (1 to default value)
[LOADER] library libcoding.so successfully loaded
e[0m[PHY] prach_config_common.rootSequenceIndex = 0
e[0me[0m[PHY] prach_config_common.prach_ConfigInfo.prach_ConfigIndex = 0
e[0me[0m[PHY] prach_config_common.prach_ConfigInfo.highSpeedFlag = 0
e[0me[0m[PHY] prach_config_common.prach_ConfigInfo.zeroCorrelationZoneConfig = 1
e[0me[0m[PHY] prach_config_common.prach_ConfigInfo.prach_FreqOffset = 2
e[0me[0m[PHY] pusch_config_common.n_SB = 1
e[0me[0m[PHY] pusch_config_common.hoppingMode = 0
e[0me[0m[PHY] pusch_config_common.pusch_HoppingOffset = 0
e[0me[0m[PHY] pusch_config_common.enable64QAM = 0
e[0me[0m[PHY] pusch_config_common.ul_ReferenceSignalsPUSCH.groupHoppingEnabled = 1
e[0me[0m[PHY] pusch_config_common.ul_ReferenceSignalsPUSCH.groupAssignmentPUSCH = 0
e[0me[0m[PHY] pusch_config_common.ul_ReferenceSignalsPUSCH.sequenceHoppingEnabled = 0
e[0me[0m[PHY] pusch_config_common.ul_ReferenceSignalsPUSCH.cyclicShift = 2
e[0me[0m[PHY] eNB 0/0 configured
e[0me[0m[RRC] [eNB] handover active state is 0
e[0me[0m[RRC] [eNB] eMBMS active state is 0
e[0me[0m[RRC] [FRAME 00000][eNB][MOD 00][RNTI 0] ENB:OPENAIR RRC IN…
e[0me[0m[ENB_APP] START MAIN THREADS
e[0mRC.nb_L1_inst:1
Initializing eNB threads single_thread_flag:0 wait_for_sync:0
e[0m[PHY] [lte-softmodem.c] eNB structure about to allocated RC.nb_L1_inst:1 RC.nb_L1_CC[0]:1
e[0me[0m[PHY] [lte-softmodem.c] eNB structure RC.eNB allocated
e[0me[0m[PHY] Initializing eNB 0 CC_id 0 single_thread_flag:0
e[0me[0m[PHY] Registering with MAC interface module
e[0me[0m[PHY] Setting indication lists
e[0me[0m[PHY] [lte-softmodem.c] eNB structure allocated
e[0mwait_eNBs()
Waiting for eNB L1 instances to all get configured … sleeping 50ms (nb_L1_inst 1)
RC.nb_L1_CC[0]:1
eNB L1 are configured
About to Init RU threads RC.nb_RU:1
Initializing RU threads
e[0me[1;31m[PHY] DJP - delete code above this /home/nano/openairinterface5g/targets/RT/USER/lte-ru.c:2741
e[0me[0m[PHY] Copying frame parms from eNB 0 to ru 0
e[0me[0m[PHY] Initializing RRU descriptor 0 : (local RF,synch_to_ext_device,0)
e[0mconfiguring ru_id 0 (start_rf 0x55e1c87ccc00)
e[0m[PHY] Starting ru_thread 0, is_slave 0, send_dmrs 0
e[0me[0m[PHY] Initializing RU proc 0 (eNodeB_3GPP,synch_to_ext_device),
e[0me[0m[PHY] init_RU_proc() DJP - added creation of pthread_prach
e[0mchannel 0, Setting tx_gain offset 0.000000, rx_gain offset 200.000000, tx_freq 2685000000.000000, rx_freq 2565000000.000000
e[0me[0m[PHY] Initializing RU signal buffers (if_south local RF) nb_tx 1
e[0me[0m[PHY] [INIT] common.txdata[0] = 0x7f074d27f040 (614400 bytes)
e[0m[LIBCONFIG] loader.dfts: 2/2 parameters successfully set, (1 to default value)
[LOADER] library libdfts.so successfully loaded
e[0me[93m[HW] thread_top_init() called with affinity>0, but overruled by #ifndef CPU_AFFINITY.
e[0me[0m[HW] [SCHED][eNB] ru_thread started on CPU 0, sched_policy = SCHED_FIFO , priority = 99, CPU Affinity= CPU_0
e[0me[0m[PHY] thread ru created id=23256
e[0me[0m[PHY] Starting RU 0 (eNodeB_3GPP,synch_to_ext_device),
e[0mwaiting for sync (ru_thread,-1/0x55e1c91cd248,0x55e1c9989ca0,0x55e1c986fa20)
e[0me[0m[HW] [SCHED][eNB] ru_thread_prach started on CPU 0, sched_policy = SCHED_FIFO , priority = 99, CPU Affinity= CPU_0
e[0me[0m[PHY] ru_thread_prach() RU configured - RACH processing thread running
e[0me[0m[PHY] nb_tx 1
e[0me[0m[PHY] rxdata_7_5kHz[0] 0x7f074d242040 for RU 0
e[0me[0m[PHY] [INIT] common.txdata_BF= 0x55e1cb9f06e0 (8 bytes)
e[0me[0m[PHY] txdataF_BF[0] 0x55e1cb9f0760 for RU 0
e[0me[0m[PHY] rxdataF[0] 0x55e1cb9fe860 for RU 0
e[0m[LIBCONFIG] device.recplay: 7/7 parameters successfully set, (7 to default value)
[LIBCONFIG] device: 1/1 parameters successfully set, (1 to default value)
[LIBCONFIG] loader.oai_device: 2/2 parameters successfully set, (1 to default value)
[LOADER] library liboai_device.so successfully loaded
LMSSDR: Initializing openair0_device for RAU …
cal 0: freq 3500000000.000000, offset 44.000000, diff 935000000.000000
cal 1: freq 2660000000.000000, offset 55.000000, diff 95000000.000000
cal 2: freq 2300000000.000000, offset 54.000000, diff 265000000.000000
cal 3: freq 1880000000.000000, offset 54.000000, diff 685000000.000000
cal 4: freq 816000000.000000, offset 79.000000, diff 1749000000.000000
e[0m[HW] [RAU] has loaded LMSSDR device.
e[0msetup_RU_buffers: frame_parms = 0x7f074a61ce68
e[0m[PHY] thread feptx created
e[0me[0m[PHY] Signaling main thread that RU 0 (is_slave 0,send_dmrs 0) is ready in state RU_RUN
e[0mwait RUs
e[0m[ENB_APP] Waiting for RUs to be configured … RC.ru_mask:00
e[0me[0m[PHY] RUs configured
e[0me[0m[ENB_APP] RC.nb_RU:1
e[0mALL RUs ready - init eNBs
e[0m[ENB_APP] Not NFAPI mode - call init_eNB_afterRU()
e[0me[0m[PHY] init_eNB_afterRU() RC.nb_inst:1
e[0me[0m[PHY] RC.nb_CC[inst]:1
e[0me[0m[PHY] RC.nb_CC[inst:0][CC_id:0]:0x7f074a61c010
e[0me[0m[PHY] [eNB 0] phy_init_lte_eNB() About to wait for eNB to be configurede[0me[0m[PHY] [eNB 0] Initializing DL_FRAME_PARMS : N_RB_DL 50, PHICH Resource 1, PHICH Duration 0 nb_antennas_tx:0 nb_antennas_rx:1 nb_antenna_ports_eNB:1 PRACH[rootSequenceIndex:0 prach_Config_enabled:1 configIndex:0 highSpeed:0 zeroCorrelationZoneConfig:1 freqOffset:2]
e[0mpcfich_reg : 0,25,50,75
e[0m[PHY] [INIT] NB_ANTENNA_PORTS_ENB:6 fp->nb_antenna_ports_eNB:1
e[0me[0m[PHY] [INIT] common_vars->txdataF[0] = 0x7f074804a040 (573440 bytes)
e[0me[0m[PHY] [INIT] common_vars->txdataF[5] = 0x7f07380a3040 (573440 bytes)
e[0me[0m[PHY] Mapping RX ports from 1 RUs to eNB 0
e[0me[0m[PHY] Overwriting eNB->prach_vars.rxsigF[0]:0x55e1cc229a00
e[0me[0m[PHY] Overwriting eNB->prach_vars_br.rxsigF.rxsigF[0]:(nil)
e[0me[0m[PHY] eNB->num_RU:1
e[0me[0m[PHY] Attaching RU 0 antenna 0 to eNB antenna 0
e[0me[0m[PHY] init_eNB_afterRU() ************* DJP ***** eNB->frame_parms.nb_antennas_tx:0 - GOING TO HARD CODE TO 1e[0me[0m[PHY] inst 0, CC_id 0 : nb_antennas_rx 1
e[0me[0m[PHY] Initialise transport
e[0me[0m[PHY] init_eNB_proc(inst:0) RC.nb_CC[inst]:1
e[0me[0m[PHY] Initializing eNB processes instance:0 CC_id 0
e[0me[0m[PHY] eNB->single_thread_flag:0
e[0me[0m[ENB_APP] ALL RUs ready - ALL eNBs ready
e[0me[0me[93m[HW] thread_top_init() called with affinity>0, but overruled by #ifndef CPU_AFFINITY.
e[0me[0m[HW] [SCHED][eNB] eNB_thread_prach started on CPU 0, sched_policy = SCHED_FIFO , priority = 99, CPU Affinity= CPU_0
e[0me[0m[HW] [SCHED][eNB] eNB_thread_prach_br started on CPU 0, sched_policy = SCHED_FIFO , priority = 99, CPU Affinity= CPU_0
e[0me[0m[ENB_APP] Sending sync to all threads
e[0mgot sync (ru_thread)
e[0m[MME_APP] Creating MME_APP eNB Task
e[0m[LIBCONFIG] MMEs.[0]: 1/1 parameters successfully set, (1 to default value)
e[0m[TMR] Created Posix thread TASK_MME_APP
e[0me[0m[MCE_APP] Creating MCE_APP eNB Task
e[0me[0m[ENB_APP] [MCE 0] MCE_app_register via M3AP for instance 0
e[0m[LIBCONFIG] MCEs.[0]: 1/1 parameters successfully set, (1 to default value)
e[0m[TMR] Created Posix thread TASK_MCE_APP
e[0me[0m[ENB_APP] TYPE TO TERMINATE
e[0m[LIBCONFIG] loader.enbscope: 2/2 parameters successfully set, (1 to default value)
Connecting to device: LimeSDR-USB, media=USB, module=FX3, addr=1d50:6108, serial=0009072C0287142A
Set sample rate 15.360000 MHz
Set TX frequency 2685.000000 MHz
[LMS] Reduce RX Gain 0 by 75.000000 dB
SR: 15.360 MHz
SR: 15.360 MHz
e[0m[PHY] RU 0 rf device ready
e[0me[0me[1;31m[MAC] SCHED_MODE = 0
e[0me[0m[PHY] rx_rf: rfdevice timing drift of 137360 samples (ts_off 959200)
e[0me[0m[PHY] prach_I0 = 0.1 dB
e[0me[0m[PHY] rx_rf: rfdevice timing drift of 163200 samples (ts_off 1096560)
e[0me[0m[PHY] rx_rf: rfdevice timing drift of 161840 samples (ts_off 1259760)
e[0me[0m[PHY] rx_rf: rfdevice timing drift of 137360 samples (ts_off 1421600)
e[0me[0m[PHY] max_I0 34, min_I0 24
