Hi, I’m checking here the LimeSDR Support for OpenSatelliteProject and I noticed something weird. When running on LimeSDR USB everything goes fine, but on Mini the signal looks overly saturated. Even putting a hardware bandpass filter before the LimeSDR doesnt help much.
Ok so I did few more tests here, and looks like the Mini SMA Connector are not good as LimeUSB ones, if I force the cable in, the NF reduces for some reason. Also adding another LNA Stage also helps a bit. I could get the same signal levels as the LimeUSB by holding the cable pressed against the lime mini, for the LimeUSB I dont need to do that.
