HI
I s there any way to post the required steps to install and configure osmocom cni + limesdr mini with ubuntu or with raspberry ?
for me i just tried to use osmocom cni with limesdr mini on ubuntu using the default .cfg files … but no luck!
the problem is with osmo-trx-lms :
> osmo-trx-lms[7995]: Sun Dec 8 18:02:03 2019 DLMS <0003> LMSDevice.cpp:94 [tid=140437169072832] Reference clock 40.00 MHz > osmo-trx-lms[7995]: Sun Dec 8 18:02:03 2019 DDEV <0002> LMSDevice.cpp:192 [tid=140437169072832] Init LMS device > osmo-trx-lms[7995]: Sun Dec 8 18:02:04 2019 DDEV <0002> LMSDevice.cpp:99 [tid=140437169072832] Sample Rate: Min=100000 Max=3.072e+07 Step=0 > osmo-trx-lms[7995]: Sun Dec 8 18:02:04 2019 DDEV <0002> LMSDevice.cpp:228 [tid=140437169072832] Setting sample rate to 1.08333e+06 4 > osmo-trx-lms[7995]: Sun Dec 8 18:02:04 2019 DDEV <0002> LMSDevice.cpp:234 [tid=140437169072832] Sample Rate: Host=1.08333e+06 RF=3.46667e+07 > osmo-trx-lms[7995]: Sun Dec 8 18:02:04 2019 DMAIN <0000> LMSDevice.cpp:209 [tid=140437169072832] Antennas configured successfully > osmo-trx-lms[7995]: Sun Dec 8 18:02:04 2019 DMAIN <0000> Threads.cpp:117 [tid=140437098583808] Thread 140437098583808 (task 8127) set name: CtrlService0 > osmo-trx-lms[7995]: Sun Dec 8 18:02:04 2019 DMAIN <0000> osmo-trx.cpp:528 [tid=140437169072832] -- Transceiver active with 1 channel(s) > osmo-trx-lms[7995]: Sun Dec 8 18:02:05 2019 DTRXCTRL <0001> Transceiver.cpp:773 [tid=140437098583808][chan=0] command is 'POWEROFF' > osmo-trx-lms[7995]: Sun Dec 8 18:02:05 2019 DTRXCTRL <0001> Transceiver.cpp:918 [tid=140437098583808][chan=0] response is 'RSP POWEROFF 0'
well, i am looking for a solution to this problem!not a priority !
but the most interested part is to use limesdr mini + osmocom + raspberry! so hope that you share a blog post about this since you managed to create a great BOX:
thanks.
