Hello, just want to confirm the frequency range of the Micro. The product page states 30 MHz - 3.8 GHz, but the docs show a discontinuous range for TX and both RX paths. Specifically the TX path lower end is 30 MHz, but both RX paths lower end is 300 MHz. Is this correct or a typo?
If this is true, does anyone know if there are performance metrics or anecdotal comments for running the RX out of spec, for example RX at 30 MHz?
Thanks!
