I could be mistaken but it could be related to power again. Writing to flash typically takes an extra 40 to 60 mA on some of the chips I have worked with. Perhaps it is enough to kill it if your motherboard can’t source the current.
I hope that is just the case Rene.
I guess I’ll know tomorrow (ordered a 6v power supply off amazon) as I dont have any suitable adapters here as all my electronics stuff is packed away currently.
its sat in the gatemismatch state currently and both limesuite and dmesg is showing it as recognised as a limesdr and connected at USB3:
[348124.476512] usb 4-1: new SuperSpeed USB device number 47 using xhci_hcd
[348124.489158] usb 4-1: LPM exit latency is zeroed, disabling LPM.
[348124.490220] usb 4-1: New USB device found, idVendor=1d50, idProduct=6108
[348124.490221] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[348124.490222] usb 4-1: Product: LimeSDR-USB
[348124.490222] usb 4-1: Manufacturer: Myriad-RF
[348124.490223] usb 4-1: SerialNumber: 0009061C02CA1F0A
I notice the FX3 boot LED keeps going red and looking at dmesg again I can see that its repeatedly dropping out and reconnecting (the USB3 connection) so prehaps it could be a power issue as you suggest.
Cheers
Hi all,
I received my LimeSDR card (version v1.4s) a few days ago,
Unfortunately I can not run the test (LimeSDR-USB Quick Test).
There is no data transfer on the FFT Viewer.
Two status LEDs are lit in green and a third flashes alternately in red and then green.
I have the same problem with windows 7 64 bits and ubuntu 16.04 with the USB 3.0 connection of my PC (core i7 3610 QM , Ivy Bridge).
Same problems with a USB 3 powered HUB and with differents cables.
After a few seconds I have this error generated
The details of the commands line are as follows:
C:\Users\Philippe>LimeUtil --info
LimeSuite information summary
Version information:
Library version: v17.06.0-PothosSDR-2017.06.21-vc14-x64
Build timestamp: 2017-06-21
Interface version: v2017.6.0
Binary interface: 17.06-1
System resources:
Installation root: C:\Program Files\PothosSDR
User home directory:
App data directory: C:\Users\Philippe\AppData\Roaming/LimeSuite
Config directory: /.limesuite
Image search paths:
- C:\Users\Philippe\AppData\Roaming/LimeSuite/images
- C:\Program Files\PothosSDR/share/LimeSuite/images
Supported connections:
- PCIEXillybus
- STREAM
- uLimeSDR
C:\Users\Philippe>LimeUtil --find
- [USB 3.0 (LimeSDR-USB), media=USB, module=STREAM, serial=0009061C02CA351F, index=0]
C:\Users\Philippe>SDRUtil --info
‘SDRUtil’ n’est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
C:\Users\Philippe>SoapySDRUtil --info
Lib Version: v0.6.1-PothosSDR-2017.06.21-vc14-x64
API Version: v0.6.0
ABI Version: v0.6
Install root: C:\Program Files\PothosSDR
Search path: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/airspySupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/audioSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/bladeRFSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/HackRFSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/LMS7Support.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/miriSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/osmosdrSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/RedPitaya.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/remoteSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/rtlsdrSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/sdrPlaySupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/uhdSupport.dll
Loading modules… Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_003.010.001.001-57-g6f87cca4
done
Available factories…airspy, audio, bladerf, hackrf, lime, miri, null, osmosdr, redpitaya, remote, rtlsdr, sdrplay, uhd
C:\Users\Philippe>SoapySDRUtil --find=“driver=lime”
Found device 0
driver = lime
index = 0
label = USB 3.0 (LimeSDR-USB) [USB] 9061C02CA351F
media = USB
module = STREAM
name = USB 3.0 (LimeSDR-USB)
serial = 0009061C02CA351F
C:\Users\Philippe>SoapySDRUtil --args=[“driver=lime”] --rate=192000 --channels=“0” --direction=“RX”
[INFO] Using format CS16.
Stream format: CS16
Num channels: 1
Element size: 4 bytes
Begin RX rate test at 0.192 Msps
Starting stream loop, press Ctrl+C to exit…
0.186069 Msps 0.744275 Bps
0.188893 Msps 0.755572 Bps
C:\Users\Philippe>SoapySDRUtil --args=[“driver=lime”] --rate=8e6 --channels=“0” --direction=“RX”
Stream format: CS16
Num channels: 1
Begin RX rate test at 8 Msps
Error in rate test: RtAudio init error 'RtApiDs::probeDeviceOpen: error (Invalid parameter) creating input buffer (Defau
lt Device)!
C:\Users\Philippe>SoapySDRUtil --args=[“driver=lime”] --rate=65e6 --channels=“0” --direction=“RX”
Stream format: CS16
Num channels: 1
Begin RX rate test at 65 Msps
lt Device)!
The measure of the USB 3 PowerMeter gives : 5.10V , 0.620 A
Do you think this is a hardware problem with my LimeSDR card?
Thank you for your help.
So tried using a 6v dc … still the same.
Its not even getting past the Westbridge state anymore.
Anyone got any more ideas
Hello Zack,
I can see that there could be some confusion about the jumper numbering as it appears to have changed with different versions of the board, your picture shows it as J17 where as the image posted at LimeSDR made simple - Part 1 shows the FX3 Boot jumper as J13.
Regards,
Bevan
Good catch! It was J13 on v1.2 boards, but is J17 on v1.4. Only the beta testing community received the former and this means that we need to get some images updated…
I still have problems
I performed additional tests with low level commands and Ubuntu 16.04
philippe@philippe-UDOO-x86:~$ SoapySDRUtil --info
Lib Version: v0.6.0-0.6.0-myriadrf1~xenial
API Version: v0.6.0
ABI Version: v0.6
Install root: /usr
Search path: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6
Search path: /usr/local/lib/x86_64-linux-gnu/SoapySDR/modules0.6
Search path: /usr/local/lib/SoapySDR/modules0.6
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libLMS7Support.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/librtlsdrSupport.so
Loading modules… done
Available factories…lime, null, rtlsdr,
philippe@philippe-UDOO-x86:~$ SoapySDRUtil --args=“driver=lime” --rate=1e6 --channels=“0” --direction=RX
[INFO] Make connection: ‘LimeSDR-USB [USB 3.0] 9061C02CA351F’
[INFO] Estimated reference clock 30.7196 MHz
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
[INFO] LMS7002M cache /home/philippe/.limesuite/LMS7002M_cache_values.db
[INFO] Ver=7, Rev=1, Mask=1
CGEN: Freq=80 MHz, VCO=2.56 GHz, INT=82, FRAC=349525, DIV_OUTCH_CGEN=15
M=156, N=3, Fvco=1040.000 MHz
M=182, N=7, Fvco=1040.000 MHz
[INFO] Rx Filter calibrated from cache
[INFO] Tx Filter calibrated from cache
CGEN: Freq=128 MHz, VCO=2.56 GHz, INT=82, FRAC=349525, DIV_OUTCH_CGEN=9
Stream format: CS16
Num channels: 1
Begin RX rate test at 1 Msps
Rx calibration using RSSI INTERNAL ON BOARD loopback
Rx ch.A @ 1904.65 MHz, BW: 30 MHz, RF input: LNAL, PGA: 12, LNA: 1, TIA: 1
Rx calibration: using cached values
Rx calibration values found in cache:
| DC | GAIN | PHASE
I: | 0 | 2047 | 0
Q: | 0 | 2047 |
Rx: 0.000 MB/s
Rx: 0.000 MB/s
Rx: 0.000 MB/s
Rx: 0.000 MB/s
Rx: 0.000 MB/s
Rx: 0.000 MB/s
Rx: 0.000 MB/s
Rx: 0.000 MB/s
I do not receive RX stream
The same command with a RTL-SDR USB Dongle
philippe@philippe-UDOO-x86:~$ SoapySDRUtil --args=“driver=rtlsdr” --rate=1e6 --channels=“0” --direction=RX
Found Rafael Micro R820T tuner
Exact sample rate is: 1000000.026491 Hz
[R82XX] PLL not locked!
[INFO] Using format CS8.
Stream format: CS8
Num channels: 1
Element size: 2 bytes
0.998394 Msps 1.99679 Bps
0.9992 Msps 1.9984 Bps
0.999457 Msps 1.99891 Bps
0.999586 Msps 1.99917 Bps
0.999668 Msps 1.99934 Bps
The Rx stream is good
with a python script and LimeSDR board
philippe@philippe-UDOO-x86:~$ python BasicStreamTests.py
[INFO] Estimated reference clock 30.7197 MHz
CGEN: Freq=640 MHz, VCO=2.56 GHz, INT=82, FRAC=349525, DIV_OUTCH_CGEN=1
===== receive a timed burst =====
Tx calibration values found in cache:
| DC | GAIN | PHASE
I: | 135 | 2047 | 144
Q: | 135 | 2047 |
| DC | GAIN | PHASE
Q: | 135 | 2047 |
| DC | GAIN | PHASE
I: | 0 | 2047 | 0
Q: | 0 | 2047 |
Rx ch.B @ 1904.65 MHz, BW: 30 MHz, RF input: LNAL, PGA: 12, LNA: 1, TIA: 1
| DC | GAIN | PHASE
I: | 0 | 2047 | 0
Q: | 0 | 2047 |
readStream for a timed burst…
ret=-1, flags=0, timeNs=0
FRx: 0.000 MB/s
[ERROR] transfer no device
terminate called without an active exception
Abandon (core dumped)
This seems to be an error of libusb
Another try with my Laptop with the last version of windows PothoSDR
Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_003.010.002.000-0-gbd6e21dc
Found device 0
driver = lime
index = 0
media = USB
module = STREAM
Lib Version: v0.6.1-PothosSDR-2017.08.13-vc14-x64
API Version: v0.6.0
ABI Version: v0.6
Loading modules… Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_003.010.002.000-0-gbd6e21dc
done
Available factories…airspy, bladerf, hackrf, lime, miri, null, osmosdr, redpitaya, remote, rtlsdr, sdrplay, uhd,
Found device 0
driver = lime
index = 0
media = USB
module = STREAM
[INFO] Make connection: ‘USB 3.0 (LimeSDR-USB) [USB] 9061C02CA351F’
[INFO] LMS7002M cache /.limesuite/LMS7002M_cache_values.db
Stream format: CS16
Num channels: 1
| DC | GAIN | PHASE
I: | 0 | 2047 | 0
Q: | 0 | 2047 |
?[1m?[31m[ERROR] No contexts left for reading data?[0m
This error seems to be generated by ConnectionSTREAM::BeginDataReading in “ConnectionSTREAM.cpp” file
And with the BasicRX program
E:\LimeSDR\Logiciels\BasicRX\Debug>BasicRX.exe
Devices found: 1
Received 0 samples
Received 0 samples
Received 0 samples
Received 0 samples
Received 0 samples
I have absolutely no data reception
@zack do you have any suggestions for me? Or do i need to speak to crowd supply about a refund??
thanks
Update on my problem - ive been speaking to Crowd supply / Lime via Email and they are sending me a new board.
Hi @phil020,
Could you send me register settings (ini) file you are using, please.
Hi @phil020,
By the way, what version of LimeSuiteGUI are you using? Could you post About window (Help -> About) printscreen, please.
The latest compiled exe file for windows is here:
https://wiki.myriadrf.org/LimeSDR-USB#LimeSuiteGUI_for_Windows
Try Quick Test Procedure with the latest software.
Hi @Zack,
I use “self_test.ini” file
My current LimeSuiteGUI software version is
The LimeSDR card infos is
When I execute the Quick Test I have the following errors
With the last version of LimeSuiteGUI I have a software crash when I execute the Quick Test
Hi @Zack,
II tried with a more recent version but unfortunately still have the error and now the software runs an infinite loop with memory saturation.
I have to interrupt it before a full saturation of the memory
Hi @phil020,
Do you press Calculate button in the CGEN tab before running FFTViewer?
Hi @Zack,
Yes.
I follow the instructions described in “https://wiki.myriadrf.org/LimeSDR-USB_Quick_Test”
but there is no data transfert on the FFT Viewer (Rx rate = 0 B/s)
and after a moment i have a repeated error “ERROR: No contexts left for reading data”
Hi @phil020,
What says LEDs?
