I see, so on the Streaming tabs of the SDR source properties, should the channel arg be “[1]” for channel 2?
I tried both [0] and [1] but I just get the same static with or without the antenna, I don’t even get noise while connecting or disconnecting the antenna. I’m using a 17.8cm u.FL SMA pigtail coaxial as antenna, not sure if that would be optimal for FM capture (<100 MHz)
nonetheless, I successfully was able to run the pothos topology replacing the LimeSDR with a NooElec RTLSDR and I get FM audio without problems with that antenna
Is there any chance I could get help on this issue? the file I’m referring to is attached as ‘simple_fm_radio_02_WORKING.pothos’ on that page. I cannot attach it here
