Hello
I am Luke and I am new user of LimeSDR and LIME Suite.
I have installed all the packages under Win10.
I would try to run the Selftest.ini and as second step to load the WCDMA wv.
LimeSDR is correctly seen by Win10 and LIME Suite connects it via USB3.0
When I try to load the ini file LIME Suite closes and this happens also with example.ini.
I also tried to load the wv from Modules–>FPGA Controls. In this case in the FPGA Controls windows I don’t have the check box to activate the “Digital LoopBack enable”.
Maybe I’m wrong, but I what I think is being done, is that RAW samples are uploaded to the RAM on the LimeSDR-USB board, they are then continuously transmitted out a TX port (DAC) that is looped back around into a RX port (ADC) where the samples are received and displayed by LimeSuite. In my mind at least this could be modified to provide the samples continuously from RAM on the host computer. But maybe I’m overlooking something that is critical.
My default action when trying to troubleshoot anything is always to use the latest LimeSuiteGUI software for Windows or install or compile the latest LimeSuiteGUI software for Linux or OSX or Window to upgrade the gateware and firmware which is currently from October 2020-10-29. I personally would not be using LimeSuiteGUI software from April 2019, because there is a chance that the firmware and gateware on the board is later than that, unless of course maybe you downgrade them to an older version. But that sounds like a step backwards to me.
