I just complied and installed the latest version. It fixed all but one of the failures. Now LNA_W fails.
Here is the Limeutil --info
Version information:
Library version: v22.09.1-g9c983d87
Build timestamp: 2023-03-03
Interface version: v2022.9.1
Binary interface: 22.09-1
Here is the Quick test info. I assume from what AndrewBack was saying the problem is just the test limits for TX_2 → LNA_W. The SDR seemed to work fine with GQRX at 30M samples per second with the 22.09.0 version.
->Start time: Fri Mar 3 19:46:20 2023
->LimeSuite version: 22.09.1-g9c983d87
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D90F82CC924B8, HW=5, GW=2.1
Serial Number: 1D90F82CC924B8
Chip temperature: 25 C
[ Clock Network Test ]
->REF clock test
Test results: 31242; 34024; 36759 - PASSED
->VCTCXO test
Results : 6710932 (min); 6710966 (max) - PASSED
->Clock Network Test PASSED
[ FPGA EEPROM Test ]
->Read EEPROM
FPGA EEPROM not supported in v2
->FPGA EEPROM Test PASSED
[ LMS7002M Test ]
->Perform Registers Test
->External Reset line test
->LMS7002M Test PASSED
[ RF Loopback Test ]
->Configure LMS
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-35.0 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-20.9 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
BTW I am running on Ubuntu 18.04. I don’t think that matters.
Thanks for all the hard work guys. The Lime Mini is a big step up for me. I am impressed with what I have learned so far.
