Hey all. I received my LimeNET-Micro and it does not appear to be working.
I have a v2.1 Micro with the rPi compute stick installed. I have flashed a microSD card with the latest raspbian. I have a keyboard connected to the USB port and a monitor on the HDMI port. On application of power, no signal on HDMI, keyboard doesn’t respond. I’m powering using USB. LED6 and LED1 are solid green. LED3 is flashing red/green, LED5 is red, and LED2 and 4 are off. What do these indicators mean? I’m powering off a 1A USB charger brick. That doesn’t meet the 2-3A figure I read. Would these indicators represent a low-voltage condition? Thanks.
1A is not sufficient and even then questionable quality power supplies will often be rated at less than what is printed on them. Documentation states 2-3A and I’d probably recommend 2.5A or more.
Personally, I always power via the DC barrel connector or Ethernet. For the DC connector you need to move J27 to pins 3+4. Then use a high quality DC power supply with a 5.5/2.1mm connector. Alternatively, if you had an active PoE switch you could use this instead, with J27 set to pins 1+2.
Thanks. I’ve now tried it with a 2A supply, and a 2.5A…same behavior. Does anyone know what the flashing LED3 means? I’d like to get this RMAed, as it’s not working.
You need to flash on module eMMC CM3 8MB not micro SD
// all in case you are using RPI delivered with LimeNET micro
in case you are using CM3 lite -> than micro SD is used
Hey all,
So there is a bit of confusion. The “Getting started” text says jumper J14, however the Flashing the eMMC text refers to J4, which on the Lime board is a micro header in a different location. I jumpered J14 on the Lime, made sure J18 is NOT jumpered, plugged in my rPI to the micro USB port and attempted to run rpiboot. It’s stuck at “Waiting for BCM2835/6/7/2711…” I did not jumper J4 on the Lime board. Thoughts?
Good, now:
Download from here https://www.balena.io/etcher/
Mac version…
Prepare less than 8 MB size of SD image,
than check what balena see with J18 open and J14 closed.
CM3 must be on LimeNET socket!
I’m assuming if I’ve gotten this far I can go ahead and flash the compute module. Is Etcher basically doing what rpiboot on the rPi is supposed to be doing?
yes
You are lucky, mine is 8MB only…
For me SdrPlay SD image was the best way,
you with 16MB do not need to free some space.
Just add Lime related SW and you are ready to go.
Can someone on the Lime Micro team verify that a failed board message is grounds for an RMA? Crowd Supply won’t start one until I get verification here. Thanks.
How can I contact someone from the Lime Microsystems team about this bad board? I really would like to get this replaced so I can get started on my projects. Thanks.
There is something wrong with communication between FPGA and EEPROM, connected to it. Currently we do not use it hence board functionality is not affected.
Get in touch with CS for RMA.
