Hi All,
I have the Streamer (v2r2) + EVB7 (using SPI from FPGA to control EVB7). Need to verify latest firmware revisions and also how to properly connect the board to Pothos using SDR source. See my Soapy response for the board below:
C:\Program Files\PothosSDR\bin>SoapySDRUtil.exe --probe=“driver=lime,module=STREAM”
Probe device driver=lime,module=STREAM
Win32; Microsoft Visual C++ version 14.0; Boost_106000; UHD_003.009.004-0-g2b5a88bb
[INFO] Make connection: ‘USB 3.0 (Stream)’
!!! Warning: firmware version mismatch !!!
Expected firmware version 5, but found version 4
[INFO] Device name: Stream
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
HOME variable is not set
LMS7002M values cache at C:\Users\apieroni\AppData\Local\Temp/.limesuite/LMS7002M_cache_values.db
[INFO] Ver=7, Rev=1, Mask=0
[INFO] SoapyLMS7::setFrequency(Rx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Tx, 0, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 0, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 0, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 0, 10 MHz), baseRate 20 MHz, factor 2
ConnectionSTREAM::ConfigureFPGA_PLL(tx=20MHz, rx=10MHz)
[INFO] SoapyLMS7::setSampleRate(Tx, 0, 10 MHz), baseRate 20 MHz, factor 2
ConnectionSTREAM::ConfigureFPGA_PLL(tx=10MHz, rx=10MHz)
[INFO] SoapyLMS7::setBandwidth(Rx, 0, 30 MHz)
[INFO] Rx Filter calibrated from cache
[INFO] SoapyLMS7::setBandwidth(Tx, 0, 30 MHz)
[INFO] Filter calibrated. Filter order-4th, filter bandwidth set to 30 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
[INFO] SoapyLMS7::setFrequency(Rx, 1, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 1, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Rx, 1, LNAL)
[INFO] SoapyLMS7::setAntenna(Tx, 1, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 1, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 1, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 1, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 1, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 1, 10 MHz), baseRate 20 MHz, factor 2
[INFO] SoapyLMS7::setSampleRate(Tx, 1, 10 MHz), baseRate 20 MHz, factor 2
[INFO] SoapyLMS7::setBandwidth(Rx, 1, 30 MHz)
[INFO] SoapyLMS7::setBandwidth(Tx, 1, 30 MHz)
– Device identification
driver=STREAM
hardware=Stream
boardSerialNumber=0x0
expansionName=UNKNOWN
firmwareVersion=4
hardwareVersion=3
protocolVersion=1
– Peripheral summary
Channels: 2 Rx, 2 Tx
Timestamps: YES
Sensors: clock_locked
