Is there any other tx project, tutorial, or examples?
This is what I am doing now.
I am using LimeSDR, and HackRF both.
I want to sending signal from LImeSDR with c++ program, and receiving signal to HackRF with gnuradio-companion.
(I already done receiving signal to LimeSDR from HackRF with c++ code )
I would really appreciate hearing your any advices or help.
There is no example for Tx only in LimeSuite repository. You can try the code below. It should set center frequency to 500 MHz, TX1_1 port and transmit single tone.
#include <iostream>
#include "lime/LimeSuite.h"
#include <thread>
#include <chrono>
#include <math.h>
using namespace std;
lms_device_t* device;
const double sampleRate = 5e6;
bool running;
const int tx_size = 1024*16;
float tx_buffer[2*tx_size];
int error()
cout << "ERROR: " << LMS_GetLastErrorMessage() << endl;
LMS_Close(device);
exit(-1);
void StreamTest()
lms_stream_t tx_stream;
tx_stream.channel = 0;
tx_stream.fifoSize = 256*1024;
tx_stream.throughputVsLatency = 0.5;
tx_stream.dataFmt = lms_stream_t::LMS_FMT_F32;
tx_stream.isTx = true;
lms_stream_meta_t meta_tx;
meta_tx.waitForTimestamp = false;
meta_tx.flushPartialPacket = false;
meta_tx.timestamp = 0;
for (int i = 0; i <tx_size; i++)
tx_buffer[2*i] = cos(2*M_PI*i/16.0);
tx_buffer[2*i+1] = sin(2*M_PI*i/16.0);
LMS_SetupStream(device, &tx_stream);
LMS_StartStream(&tx_stream);
while (running)
int ret = LMS_SendStream(&tx_stream,tx_buffer,tx_size,&meta_tx,1000);
if (ret != tx_size)
cout << "error: samples sent: " << ret << "/" << tx_size << endl;;
LMS_StopStream(&tx_stream);
LMS_DestroyStream(device,&tx_stream);
int n= LMS_GetDeviceList(nullptr);
if (n > 0)
if (LMS_Open(&device,NULL,NULL)!=0) //open first device
error();
if (LMS_Init(device)!=0)
error();
if (LMS_EnableChannel(device,LMS_CH_TX,0,true)!=0)
error();
if (LMS_SetSampleRate(device,sampleRate,0)!=0)
error();
if (LMS_SetLOFrequency(device,LMS_CH_TX, 0, 500e6)!=0)
error();
if (LMS_SetAntenna(device, LMS_CH_TX, 0, LMS_PATH_TX1)!=0) //TX1_1
error();
running = true;
std::thread thread = std::thread(StreamTest);
this_thread::sleep_for(chrono::seconds(10));
running = false;
thread.join();
if (LMS_Close(device)==0)
cout << "Closed" << endl;
return 0;
