I test some project control signal on 27mhz, but set frequency to below 30mhz result still 30mhz.
How let it work change code and reprogram?
I get similar code like “if (targetRfFreq < 30e6) targetRfFreq = 30e6;”, i changed but not work.
Whether some similar code on FPGA , driver or FX?
Please help me !
I think this is where you would need to engage the NCO. @IgnasJ should be able to advise.
Ok how to set
GNU radio uses SaopySDR and as far as I know SoapySDR should be using NCO automatically when <30MHz.
