Cuba was booming last night @ 6.165MHz and 26.165MHz. with LPF only.
Should be nothing heard @26MHz.
Sent -73dBm signal (5 and 9 translation) to modified LNA_L (EasyFix2) input using SDR Console v3.0 Preview. To get same reading( -73dBm) @ SDR Console v3.0 Preview following settings used:
Settings: LNA PGA TIA
Freq 1.92MHz -1 Max 0
3.65MHz -30 -3 -2
7.20MHz -30 -3 -12
14.2MHz -27 -12 -12
21.2MHz -27 -12 -12
28.2MHz -27 -12 -6
Separate observation:
Even with LPF (0-30MHz) and BPF (14MHz) in line few artifacts at 5MHz bandwidth, 4-5/band on 20M, not a big deal, but may need some work @ LimeSDR side to remove them. Same observed using HDSDR.
Hardware V1.4 W10/64
73,
Yuri N3QQ
