I did a new Ubuntu 16.04 install with a new lime gqrx install. I’m getting the following error at gqrx radio startup:
terminate called after throwing an instance of ‘std::runtime_error’
what(): In hierarchical block source_impl, output 1 is not connected internally
Aborted (core dumped)
Has anyone seen this? It seems likely to be audio output related, but there really isn’t enough info to tell for sure. I guess I’m regretting all the semi-cryptic debug outputs I’ve coded over the years.
this is a problem with same gnuradio block. It is reporting different signature than expected (described). What I/O device are you using? Is it happening with another one? I`d try to remove the gqrx configuration (~/.config/gqrx) and reinstalling all the related software.
The output is the default audio device, the speaker. I let GQRX just go with the default, but I have tried changing it to see if that made a difference. It didn’t.
