here is my sequence to successfully install
GnuRadio_3.11 with LimeSuiteNG_0.3.0 on Ubuntu_2025.10
and use it with LimeSDR_Mini2.2
//1. On a fresh Ubuntu_2025.10 installation:
(Software updater → check for updates)
//2. Some prerequisites
sudo apt install libpeas-dev
sudo apt install gedit
sudo apt install open-vm-tools
sudo apt install libusb-dev
sudo apt install git
sudo apt install cmake
sudo apt install gnuplot
sudo apt install libwxgtk3.2-dev
sudo apt install doxygen
sudo apt install glew-utils
sudo apt install libglew-dev
sudo apt install liborcus-dev
//3. Install Volk
cd $HOME
git clone --recursive GitHub - gnuradio/volk: The Vector Optimized Library of Kernels
cd volk
mkdir build
cd build
cmake -DCMAKE_BUILD_TYPE=Release ../
make
make test
sudo make install
sudo ldconfig
//3.1 Run Volk Profile
cd $HOME/volk/build/apps
volk_profile
//4. Installing prerequisites for GnuRadio
sudo apt install libboost-all-dev
sudo apt install libqt5opengl5-dev
//Here we can install all module
//sudo apt install soapysdr-module-all
// Or only those I have
sudo apt install soapysdr-module-lms7
sudo apt install soapysdr-module-rtlsdr
sudo apt install libiio-dev
sudo apt install libsoapysdr-dev
sudo apt install python3-numpy
sudo apt install python3-pygccxml
sodo apt install python3-pybind11
sudo apt install libgmp-dev
sudo apt install libspdlog-dev
sudo apt install libfftw3-dev
sudo apt install libad9361-dev
sudo apt install libzmq3-dev
// Only for UHD required
// sudo apt install libuhd-dev
sudo apt install libcodec2-dev
sudo apt install libjack-dev
sudo apt install libunwind-dev
sudo apt install libgsl-dev
sudo apt install libgsm1-dev
sudo apt install libsndfile1-dev
sudo apt install libqwt-qt5-dev
sudo apt install pyqt5-dev
sudo apt install python3-gi-cairo
sudo apt install python3-pyqt5
sudo apt install libqt5svg5-dev
sudo apt install libasound2-dev
sudo apt install libportaudio2
sudo apt install python3-matplotlib
//5. Installing GNU Radio
cd $HOME
git clone GitHub - gnuradio/gnuradio: GNU Radio – the Free and Open Software Radio Ecosystem
cd gnuradio
mkdir build
cd build
cmake -DCMAKE_BUILD_TYPE=Release -DENABLE_GR_UHD=OFF ../
// Here must the following module list enabled
*-- # Gnuradio enabled components *
– * testing-support
– * python-support
– * post-install
– * doxygen
– * man-pages
– * gnuradio-runtime
– * gr-ctrlport
– * gnuradio-companion
– * JSON/YAML config blocks
– * gr-blocks
– * gr-fec
– * gr-fft
– * gr-filter
– * gr-analog
– * gr-digital
– * gr-dtv
– * gr-audio
– * * alsa
– * * oss
– * * jack
– * gr-channels
– * gr-pdu
– * gr-iio
– * * libad9361
– * gr-qtgui
– * gr-trellis
– * gr-utils
– * gr_modtool
– * gr_blocktool
– * gr-vocoder
– * * codec2
– * * freedv
– * * gsm
– * gr-wavelet
– * gr-zeromq
– * gr-network
– * gr-soapy
*-- # Gnuradio disabled components *
– * gr-uhd
– * gr-uhd UHD 4.0 RFNoC
– * gr-video-sdl
make -j4
make test
// 261 tests passed
// 8 qa_zeromq tests failed!
sudo make install
sudo ldconfig
//6. Install LimeSuiteNG
git clone GitHub - myriadrf/LimeSuiteNG
cd LimeSuiteNG
//edit install_dependecies.sh
// change VersionId: If 25.10 then 24.04
sudo ./install_dependencies.sh
cmake -B build
cd build
make
sudo make install
sudo ldconfig
// That’s it. On my system, now I can use the GnuRadio with LimeMini2.2
