Decided to update limesuite and see if limesuitecaibrate.py had been fixed because the limeutil --calibrate brakes HF reception … error error error … why for do you error
– Build files have been written to: /home/kc7noaa/Downloads/LimeSuite/build
kc7noaa@odroid64:~/Downloads/LimeSuite/build$ make -j4
[ 1%] Building CXX object src/oglGraph/CMakeFiles/oglGraph.dir/dlgMarkers.cpp.o
[ 2%] Building CXX object src/oglGraph/CMakeFiles/oglGraph.dir/GLFont.cpp.o
c++: error: unrecognized command line option ‘-mfpmath=both’
[ 3%] Building CXX object src/oglGraph/CMakeFiles/oglGraph.dir/OpenGLGraph.cpp.o
src/oglGraph/CMakeFiles/oglGraph.dir/build.make:62: recipe for target ‘src/oglGraph/CMakeFiles/oglGraph.dir/dlgMarkers.cpp.o’ failed
make[2]: *** [src/oglGraph/CMakeFiles/oglGraph.dir/dlgMarkers.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs…
src/oglGraph/CMakeFiles/oglGraph.dir/build.make:86: recipe for target ‘src/oglGraph/CMakeFiles/oglGraph.dir/GLFont.cpp.o’ failed
make[2]: *** [src/oglGraph/CMakeFiles/oglGraph.dir/GLFont.cpp.o] Error 1
src/oglGraph/CMakeFiles/oglGraph.dir/build.make:110: recipe for target ‘src/oglGraph/CMakeFiles/oglGraph.dir/OpenGLGraph.cpp.o’ failed
make[2]: *** [src/oglGraph/CMakeFiles/oglGraph.dir/OpenGLGraph.cpp.o] Error 1
CMakeFiles/Makefile2:280: recipe for target ‘src/oglGraph/CMakeFiles/oglGraph.dir/all’ failed
make[1]: *** [src/oglGraph/CMakeFiles/oglGraph.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
[ 4%] Building CXX object src/CMakeFiles/LimeSuite.dir/Logger.cpp.o
[ 5%] Building CXX object src/CMakeFiles/LimeSuite.dir/ADF4002/ADF4002.cpp.o
[ 6%] Building CXX object src/CMakeFiles/LimeSuite.dir/ErrorReporting.cpp.o
src/CMakeFiles/LimeSuite.dir/build.make:110: recipe for target ‘src/CMakeFiles/LimeSuite.dir/ADF4002/ADF4002.cpp.o’ failed
make[2]: *** [src/CMakeFiles/LimeSuite.dir/ADF4002/ADF4002.cpp.o] Error 1
src/CMakeFiles/LimeSuite.dir/build.make:62: recipe for target ‘src/CMakeFiles/LimeSuite.dir/Logger.cpp.o’ failed
make[2]: *** [src/CMakeFiles/LimeSuite.dir/Logger.cpp.o] Error 1
src/CMakeFiles/LimeSuite.dir/build.make:86: recipe for target ‘src/CMakeFiles/LimeSuite.dir/ErrorReporting.cpp.o’ failed
make[2]: *** [src/CMakeFiles/LimeSuite.dir/ErrorReporting.cpp.o] Error 1
[ 6%] Building CXX object src/CMakeFiles/LimeSuite.dir/lms7002m_mcu/MCU_BD.cpp.o
src/CMakeFiles/LimeSuite.dir/build.make:134: recipe for target ‘src/CMakeFiles/LimeSuite.dir/lms7002m_mcu/MCU_BD.cpp.o’ failed
make[2]: *** [src/CMakeFiles/LimeSuite.dir/lms7002m_mcu/MCU_BD.cpp.o] Error 1
CMakeFiles/Makefile2:170: recipe for target ‘src/CMakeFiles/LimeSuite.dir/all’ failed
make[1]: *** [src/CMakeFiles/LimeSuite.dir/all] Error 2
Makefile:129: recipe for target ‘all’ failed
make: *** [all] Error 2
