I tried to build Limesuite for Nvidia Orin NX (arm64, Ubutu 22), but got the following errors:
$ cmake ..
– Enabling native optimizations
– Building KissFFT with datatype: float
– Building static library
– PKGINCLUDEDIR is include/kissfft
CMake Error at external/CMakeLists.txt:118 (add_library):
add_library INTERFACE library requires no source arguments.
CMake Error at external/CMakeLists.txt:119 (target_include_directories):
Cannot specify include directories for target “cpp-feather-ini-parser”
which is not built by this project.
– Found libusb-1.0:
– - LIBUSB_1_INCLUDE_DIRS: /usr/include/libusb-1.0
– - LIBUSB_1_LIBRARIES: /usr/lib/aarch64-linux-gnu/libusb-1.0.so
– Could NOT find Gnuplot (missing: GNUPLOT_EXECUTABLE)
– wxWidgets_DEFINITIONS: _FILE_OFFSET_BITS=64;WXUSINGDLL;WXGTK
– wxWidgets_INCLUDE_DIRS: /usr/lib/aarch64-linux-gnu/wx/include/gtk3-unicode-3.0;/usr/include/wx-3.0
– wxWidgets_LIBRARIES: -L/usr/lib/aarch64-linux-gnu;-pthread;;;-lwx_gtk3u_richtext-3.0;-lwx_gtk3u_adv-3.0;-lwx_gtk3u_core-3.0;-lwx_baseu-3.0;-lwx_gtk3u_gl-3.0
– OPENGL_INCLUDE_DIR: /usr/include
– OPENGL_LIBRARIES: /usr/lib/aarch64-linux-gnu/libOpenGL.so;/usr/lib/aarch64-linux-gnu/libGLX.so;/usr/lib/aarch64-linux-gnu/libGLU.so
– Module Soapy_limesuiteng configured with version: 0.2.0
– Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
– Packages found:
- Threads
- libusb-1.0
Adds USB communication support
- wxWidgets
- OpenGL
- SoapySDR
Adds LimeSuiteNG bindings for SoapySDR
– Missing required packages:
– Missing recommended packages:
– Missing optional packages:
– ## LimeSuiteNG enabled features
- HEADERS, The limesuiteng headers
- LIBRARY, The limesuiteng library
- USB_FTDI, USB support for FTDI
- USB_FX3, USB support for Cypress FX3
- LIMEPCIE, PCIe support
- LIMEPCIE_KERNEL_MODULE, Build Linux LimePCIe kernel module
- EXAMPLES, LimeSuite library API examples
- CLI, LimeSuite command line interface tools
- GUI, GUI Application for LimeSuite
- AMARISOFT_PLUGIN, LimeSuite Amarisoft integration plugin
- DESKTOP, LimeSuiteNG freedesktop integration
- SOAPYSDR, SoapySDR bindings for LimeSuiteNG
- UDEV_RULES, Install Linux udev rules
– ## LimeSuiteNG disabled features
- DKMS, DKMS support for lime PCIe kernel module
- GNURADIO, GNU Radio 3.9+ Plug-in
- DOXYGEN, Build Doxygen documentation
– Install prefix: /usr/local
– Build timestamp: 2024-08-16
– Lime Suite version: 0.2.0-unknown
– ABI/so version: 0.2-1
– Configuring incomplete, errors occurred!
See also “/home/ubuntu/lms/LimeSuiteNG-develop/build/CMakeFiles/CMakeOutput.log”.
See also “/home/ubuntu/lms/LimeSuiteNG-develop/build/CMakeFiles/CMakeError.log”.
Thanks for quick response. The update fixed some errors. I still got few errors (dependency related?).
cmake -B build && cd build
– cmake version: 3.16.3
– The C compiler identification is GNU 9.4.0
– The CXX compiler identification is GNU 9.4.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
CMake Error at external/CMakeLists.txt:119 (target_sources):
target_sources may only set INTERFACE properties on INTERFACE targets
– Performing Test HAVE_CXX_ATOMICS_WITHOUT_LIB
– Performing Test HAVE_CXX_ATOMICS_WITHOUT_LIB - Success
– Performing Test HAVE_CXX_ATOMICS64_WITHOUT_LIB
– Performing Test HAVE_CXX_ATOMICS64_WITHOUT_LIB - Success
– Looking for pthread.h
– Looking for pthread.h - found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
– Check if compiler accepts -pthread
– Check if compiler accepts -pthread - yes
– Found Threads: TRUE
– Found libusb-1.0:
– Found wxWidgets: -L/usr/lib/aarch64-linux-gnu;-pthread;;;-lwx_gtk3u_richtext-3.0;-lwx_gtk3u_adv-3.0;-lwx_gtk3u_core-3.0;-lwx_baseu-3.0;-lwx_gtk3u_gl-3.0 (found version “3.0.4”)
– Found OpenGL: /usr/lib/aarch64-linux-gnu/libOpenGL.so
– Found Git: /usr/bin/git (found version “2.25.1”)
– Module Soapy_limesuiteng configured with version: 0.2.0-e17ae254
– Packages found:
- Threads
- libusb-1.0
- wxWidgets
- OpenGL
- SoapySDR
- Git
– Build timestamp: 2024-08-19
– Lime Suite version: 0.2.0-ge17ae254
See also “/home/ubuntu/lms/LimeSuiteNG/build/CMakeFiles/CMakeOutput.log”.
See also “/home/ubuntu/lms/LimeSuiteNG/build/CMakeFiles/CMakeError.log”.
I was able to install missing “gnuplot” and “doxygen”.
There is still error for "######################################################
I have the following header files under /usr/src":
drwxr-xr-x 6 root root 4096 Aug 15 10:51 linux-headers-5.10.192-tegra-ubuntu20.04_aarch64
drwxr-xr-x 7 root root 4096 Aug 16 07:33 linux-headers-5.15.0-117-generic
Fixed the:
If you have installed kernel headers you can ignore the warning
LinuxKernelHeaders"
The cmake detection script does not handle all naming schemes and directories. But the kernel module build system will find them.
I commented out the following:
#find_package(LinuxKernelHeaders REQUIRED)
in “LimeSuiteNG/src/comms/PCIe/linux-kernel-module/CMakeList.txt”
but still got the following errors. There is no “makefile” generated.
$ cmake ..
– Found libusb-1.0:
– Packages found:
- Threads
- libusb-1.0
- Gnuplot
- wxWidgets
- OpenGL
- SoapySDR
- Git
- Doxygen
pull latest changes from ‘develop’ branch
The update worked without any error. I was able to run "make’, “sudo make install”, “sudo ldconfig”, “limeGUI”, have Lime XTRX detected and run some tests.
Thanks!
