Hi all,
I got two LimeSDR boards. One is working quite well, but I frequently struggle with strange initialization-related problems on the other one. Sometimes it works like a charm and nothing wrong is happening, other time I got USB-related errors like “No transfer from device”, but most frequently I got errors like “ResetChip() failed” or some sampling rate- or bandwith-related errors. It does not really matter what application I am trying to use, it happens e.g. when trying to run GNU Radio flowgraph or run custom C++ application based on SoapySDR etc. At the same time I don’t have any of those problems with the first board, so it is clearly hardware-related issue, not a software thing nor USB power supply or host machine issue. I hope you will be able to provide some hints what is happening.
Below I have posted example errors (lines which begins with timestamp are coming from my app, while other are coming from SoapySDR or underlying LMS7 driver):
- Problem with setBandwidth() function right at the beginning, even before I try to set anything on my own:
2017-10-01 19:55:16.838314 INFO - sdr: Creating the SDR device with: args=type=soapy,driver=lime,soapy=0,cacheCalibrations=0
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.002.HEAD-0-gbd6e21dc
[INFO] Make connection: 'LimeSDR-USB [USB 3.0] 9062000C4220F'
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
[INFO] Ver=7, Rev=1, Mask=1
[ERROR]
[WARNING] SoapyLMS7::setSampleRate(): not a power of two factor: TSP Rate = 15.36 MHZ, Requested rate = 10 MHz
[ERROR]
[ERROR]
[ERROR] setBandwidth(Rx, 0, 30 MHz) Failed -
2017-10-01 19:55:17.561692 ERROR - sdr: Following exception occurred during initialization of the SDR device:
- After that, it does not detect gateware etc. and it constantly gives me ResetChip() error message and the only way to avoid that is to unplug and plug USB cable again. Then it may work fine or go into any of 1. 2. or 3. states.
2017-10-01 19:56:15.950352 INFO - sdr: Creating the SDR device with: args=type=soapy,driver=lime,soapy=0,cacheCalibrations=0
Expected gateware version 2, revision 9
[INFO] Ver=0, Rev=0, Mask=0
2017-10-01 19:56:15.988909 ERROR - sdr: Following exception occurred during initialization of the SDR device: ResetChip() failed
- Sometimes I also observe problems with setting sampling rate which I have requested - device is actually using much smaller values. Moreover TX/RX PLL can’t lock. After killing the app device goes into state 2.:
2017-10-01 19:58:27.436163 INFO - sdr: Trying to set the following TX sample rate on channel 0: 16.666667 [MHz]
[ERROR]
2017-10-01 19:58:27.747197 INFO - sdr: Actual TX sample rate on channel 0: 7.680000 [MHz]
2017-10-01 19:59:24.975906 INFO - sdr: Trying to set the following RX sample rate on channel 0: 16.666667 [MHz]
[ERROR]
2017-10-01 19:59:28.352797 INFO - sdr: Actual RX sample rate on channel 0: 1.920000 [MHz]
Have u got some ideas what the heck is happening here or what may be causing that kind of problems?
But I guess you are right and replacement is the only reasonable way to go.
