As I setup the mini sdr v2 I get the following messages. Can someone tell me which ones are errors and how to correct them?
thanks,
set_rx_frequency:448 Set RX frequency 1400000000.000000
set_rx_bandwidth:519 Set RX bandwidth 312500.000000
RXLPF set to 1.400 MHz (requested 0.312 MHz [out of range])
RX LPF configured
set_rx_bandwidth:534 Get RX bandwidth 1400100.000000
set_rx_samplerate:564 Set RX sample rate 274285.000000
SetFrequencyCGEN(1.09714 MHz) - cannot deliver requested frequency
set_rx_samplerate:568 error setting RX sample rate (SetFrequencyCGEN(1.09714 MHz) - cannot deliver requested frequency)
set_rx_samplerate:576 RX sample rate host 15359999.757064 link 15359999.757064
set_rx_gain:619 Set RX gain 40
set_rx_agc_mode:706 fixme
Calibrating Rx for 2.5 MHz (requested 0.3125 MHz [out of range])
Rx calibration finished
set_tx_frequency:471 Set TX frequency 1400000000.000000
set_tx_bandwidth:494 Set TX bandwidth 312500.000000
TXLPF set to 5.000 MHz (requested 0.312 MHz [out of range])
Filter calibrated. Filter order-4th, filter bandwidth set to 5 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
TX LPF configured
set_tx_bandwidth:511 Get TX bandwidth 5000000.000000
set_tx_samplerate:543 Set TX sample rate 274285.000000
set_tx_samplerate:547 error setting TX sample rate (SetFrequencyCGEN(1.09714 MHz) - cannot deliver requested frequency)
set_tx_samplerate:555 TX sample rate host 15359999.757064 link 15359999.757064
set_tx_gain_relative:599 Set TX gain 50
rxtx_init:693 fixme
Calibrating Tx for 2.5 MHz (requested 0.3125 MHz [out of range])
Tx calibration finished
configure:248 Lime SDR Mini V2 is configured
