I am getting this error. Is there a way to get the best sample rate for the mini v2 from a “requested” sample rate?
set_rx_samplerate:552 Set RX sample rate 274285.000000
SetFrequencyCGEN(1.09714 MHz) - cannot deliver requested frequency
set_rx_samplerate:556 error setting RX sample rate SetFrequencyCGEN(1.09714 MHz) - cannot deliver requested frequency
the requested 274285 Hz is a very low sampling rate, it is lower than what the clock generator can provide directly. To achieve this 274285 sample rate, you need to increase oversampling ratio to 8.
So the minimum sample rate is what the clock generator is set to?
configure:190 clock LMS_CLOCK_REF freq 40000000.000000
configure:190 clock LMS_CLOCK_SXR freq 1400000000.000000
configure:190 clock LMS_CLOCK_SXT freq 1400000000.000000
configure:190 clock LMS_CLOCK_CGEN freq 4388559.982181
configure:190 clock LMS_CLOCK_RXTSP freq 1097139.995545
configure:190 clock LMS_CLOCK_TXTSP freq 1097139.995545
Is there anyway to set the clock generator? Is there a specific range?
Thanks,
M
CGEN range is 5-640 MHz
Sample rate equation is: sampleRate = CGEN/(4 * oversampling)
So to get your 274285Hz sample rate, the oversampling has to be at least 8, to bring CGEN into supported range.
Calling LMS_SetSampleRate(device, 274285, 8); will give your requested rate.
I am porting the driver to an embedded system that doesn’t have alot of processing power. Since I don’t have alot of processing power, I need to keep the sample rate low to reduce the data throughput and load on the CPU. If I set the oversample to 8 that will generate significantly more data (8 * 274285 * 32 bits/sec ).
It’s the RF oversampling(decimation/interpolation), it is done inside the LMS7002M chip itself, so no processing power is needed from your host system, the digital sample rate will remain the same 274285Hz.
