From other posts in the forum the Lime GUI allows LimeSDR users to change the clock source to use the external reference clock (REF_CLK_IN).
I am using a LimeSDR with an OAI eNodeB. Does anyone know if the OAI eNodeB flag --external-clock will tell the LimeSDR to use the external clock source.
As far as I can see this does not appear to be implemented in lms_li.cpp in OAI so the clock_source will not get passed to the LimeSDR but I was hoping someone knowledgeable would confirm this.
If I wanted to add this functionality, what API call do I use in lms_lib.cpp (LMS_xyz) ?
I just did that recently - sorry for the delay In
openairinterface5g/targets/ARCH/LMSSDR/USERSPACE/LIB/lms_lib.cpp
which of course loads the ini and wipes everything out I supposed, so it has to go in late - I put it here:
printf("Set TX frequency %f MHz\n",device->openair0_cfg[0].tx_freq[0]/1e6);
/* this was commented out */
printf("Override antenna settings to: RX1_H, TXA_2\n");
LMS_SetAntenna(lms_device, LMS_CH_RX, 0, 1);
LMS_SetAntenna(lms_device, LMS_CH_TX, 0, 2);
// use external printf(“Setting external clock \n”); LMS_SetClockFreq(lms_device, LMS_CLOCK_EXTREF, 10000000);
for (int i = 0; i< device->openair0_cfg->rx_num_channels; i++)
if (LMS_SetLPFBW(lms_device,LMS_CH_RX,i,device->openair0_cfg->rx_bw)!=0)
printf("RX ch:%d filter calibration failed, bw:%fMHz\n%s\n",i,device->openair0_cfg->rx_bw/1e6,LMS_GetLastErrorMessage());
and the green light now comes on always. I don’t know how to make it cmd line switchable right off.
The author also has a magic number to trim their on board oscillator that may not apply to everyone else - just comment this out if using an external clock - this is how it gets reset back to internal anyway:
