I’ve been following the Quick Start guide for my LimeSDR Mini and am getting the following error when I open self_test.ini in LimeSuiteGUI:
[19:27:43] INFO: Disconnected control port
[19:27:48] INFO: Reference clock 40.00 MHz
[19:27:48] INFO: Connected Control port: LimeSDR-Mini FW:5 HW:0 Protocol:1 GW:1.24 Ref Clk: 40.00 MHz
[19:27:54] ERROR: SetFrequencyCGEN(60.5437 MHz) failed
Is this a known issue at all?
Some background: I’m on macOS and have built LimeSuite from source, in order to overcome the issue in this thread where the version in brew is outdated: LimeSDR USB works fine but LimeSDR-mini will not work
LimeUtil --find returns:
* [LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3ACA069CE7D7]
SoapySDRUtil --find returns:
SoapySDRUtil --find
## Soapy SDR – the SDR abstraction library
No devices found!
Clearly this also isn’t correct, but I thought Id try to get through the quick start guide first!
