Got my LimeSDR board this morning (Germany)
I’m following the instructions given here: https://wiki.myriadrf.org/LimeSDR-USB_Quick_Test
Got to Section 3.6, step 3, Click ‘W-CMDA’
The response is “File not found lma7suite_wfm/wcdma.wfm”
That folder and file exists in my Downloads folder.
That is probably not the correct place, so where should they go?
Windows 10 AE x86_64
LimeSuite 17.01.1-PothosSDR-2017.02.02-vc1
The answer is in the message
You should put it to “lma7suite_wfm/wcdma.wfm” i.e. there should be folder “lma7suite_wfm” in the same level as LimeSuiteGUI executable and this folder should contain wfm files.
I think it’s actually a typo and should be “lms7suite_wfm/wcdma.wfm”. On Linux, and presumably OS X, this would be relative to where you launched LimSuiteGUI from. Not sure about Winwdows… Relative to “My Documents”?
FIXED
Found \Program Files\PothosSDR\bin\lms7suite_wfm
This folder was empty.
Copied files from downloaded and unpacked ‘lms7suite_wfm.gz’* archive into the folder.
Section 3.6, step 3 now works as expected.
Now failing at section 3.7. Reporting my OpenGL version as being v1.
That will be another story…
*Edge downloaded the archive file with a ‘.gz’ extension.
Had to rename it to ‘.tgz’ so that WinZip could unpack it correctly.
Download the lms7suite_wfm file and rename it to wcdma.wfm then, on windows 10 at least, create a folder called 'lms7suite_wfm in the ‘bin’ folder and chuck the wcdma.wfm file into it.
