Hello @Zack
This is with reference to the terminology in the Programming guide and the connection to the waveforms in the datasheet.
There is the use of the word “Frame” which I am unable to trace.
Reg 0x0023, LMLx_FIDM: frame start ID selection. What does this mean?
Reg 0x0024, Sample source in positions 0,1,2,3. Where are these positions defined?
Is the TRXIQPULSE mode same as JESD 207 mode? -
From the FPGA code I understood that there are four modes of operation of the limelight interface:
1) SISO_DDR
2) SISO_SDR
3) MIMO_DDR
4) PULSE_DDR
Please advise on how are these configured.
3.1) Register 0x0022, LMLx_SISODDR (DDR mode off/on). Does turning it OFF enable SISO_SDR mode ON?
3.2) How is MIMO_DDR mode enabled (does turning OFF TRXIQPULSE mode off enable MIMO_DDR)?
3.3) Could you please provide the waveform for SISO_DDR mode? My understanding is the following:
Figs 33-36: are PULSE_DDR/JESD 207 mode
Figs 37-38: are MIMO-DDR mode which is same as TRXIQ DDR mode
Figs 39-40: are SISO-SDR mode
Thanks as always for your time and help,
