I’ve received my v1.4 board and tried to update it after getting the “gateware version mismatch” error message. The update in LimeSuiteGUI failed, but I didn’t record the exact error message I received. Now the board presents with the Cypress bootloader (04b4:00f3).
I’ve tried following Zack’s instructions in the LimUtil --update scrogged - how to start over? thread with both the linked firmware image from github and LimeSDR-USB_HW_1.3_r3.0.img. The “Firmware to RAM” stage completes fine, and I then see the OpenMoko USB device (1d50:6108).
Attempting to program “Firmware to Flash” in LimeSuiteGUI fails with an unhelpful “Programming failed!” popup. If I run the “Firmware to RAM” stage in LimeSuiteGUI (so I have the OpenMoko device visible) and then try to program the flash with “sudo LimeUtil --fw=LimeSDR-USB_HW_1.3_r3.0.img” I get this output:
Connected to [USB 3.0 (LimeSDR-USB), media=USB, module=STREAM, addr=1d50:6108, serial=0009060B00462716]
Estimated reference clock 30.7195 MHz
Selected reference clock 30.720 MHz
[ 7%] 12512/186040 Bytes Programming failed! Write operation failed
Programming failed! : Programming failed! Write operation failed
with the progress indicator counting up until it barfs out at 7%
Do I have a b0rked board? Is there anything else I can try? How do I get this working?
