I see the hex file inside of LMS7002m has been updated for Limesuite 20.10.
Do we need to program it manually?
What is the standart procedure?
LimeSuite --update is the only board related update you should need to do. AFAIK Lime Suite will take care of programming the LMS7002M MCU when required.
