I’ve been trying make sure I’m using the most up to date version of osmo-trx but, I just can’t seem to get a working install. I was using the MyriadRF/Osmo-TRX fork and that worked fine with both OpenBTS and OsmoNITB. However, my understanding is that the LimeSDR functionality has since been merged into the main OsmoTRX branch and so there is no longer a need for the MyriadRF fork. I assumed some potential improvements has been made as well. I’ve installed the most current LimeSuite from git and the most current OsmoTRX from git with no apparent errors. However, I experience one of two outcomes when I try to use the osmo-trx -e -a “driver=lime,device=0” with OsmoNITB.
It gets stuck at this step and the indicator lights on the lime remain green, despite claiming the TRX is active…
sudo osmo-trx -e -a "driver=lime,device=0"
linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_003.010.002.000-3-g122bfae1
opening configuration table from path :memory:
Info: SSE3 support compiled in and supported by CPU
Info: SSE4.1 support compiled in and supported by CPU
Config Settings
Log Level............... NOTICE
Device args............. driver=lime,device=0
TRX Base Port........... 5700
TRX Address............. 127.0.0.1
GSM Core Address.........127.0.0.1
Channels................ 1
Tx Samples-per-Symbol... 4
Rx Samples-per-Symbol... 4
EDGE support............ Enabled
Reference............... Internal
C0 Filler Table......... Disabled
Multi-Carrier........... Disabled
Tuning offset........... 0
RSSI to dBm offset...... 0
Swap channels........... 0
-- Make connection: 'LimeSDR-USB [USB 3.0] 9062000C42715'
-- Reference clock 30.720 MHz
-- Device name: LimeSDR-USB
-- Reference: 30.72 MHz
-- Init LMS7002M(0)
-- Ver=7, Rev=1, Mask=1
-- LMS7002M calibration values caching Disable
-- Transceiver active with 1 channel(s)
or
I run the same command with a continual cylcing of the TRX with lots of continual error messages like…
ERR 139886685017856 09:36:02.7 UHDDevice.cpp:1095:readSamples: Sample buffer: Requested timestamp is not valid
ERR 139886685017856 09:36:02.7 UHDDevice.cpp:1096:readSamples: timestamp = 2103920, length = 262144, time_start = 5832905, time_end = 5833040, data_start = 183641, data_end = 183776
ALERT 139886685017856 09:36:02.7 radioInterface.cpp:374:pullBuffer: Receive error 0
There may be something I’ve overlooked in the install. Maybe I have to recompile uhd, soapysdr, soapysdr-uhd?
Any help is appreciated, Thanks.
Ben
