So I’m doing some work with Nucleo STM32 and some play with the LimeSDR-Mini on Arch Linux, but can’t do both at the same time, not that it would be healthy or productive…
The STM32 development board enumerates as a serial port, usually /dev/ttyACM0, which lime confuses for something else:
$ LimeUtil --find
* [EVB7 (/dev/ttyACM0), media=COM, module=EVB7COM, addr=/dev/ttyACM0]
* [LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3AC6EEA46E50]
* [Remote, media=TCP, module=Z_Remote]
So when I try to use the device through soapy it doesn’t work:
$ ./SimpleSiggen.py --args driver=lime,serial=1D3AC6EEA46E50 --rate 7.68e6 --freq 433.92e6 --txGain 20 --waveFreq 0
[INFO] Make connection: 'EVB7 (/dev/ttyACM0) [COM] 1D3AC6EEA46E50'
[INFO] RemoteControl Listening on port: 5000
[ERROR] Read(64 bytes) failed
free(): invalid next size (fast)
Aborted (core dumped)
or
$ gqrx
gr-osmosdr v0.1.4-127-g4d83c606 (0.1.5git) gnuradio 3.7.13.4
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
Resampling audio 96000 -> 48000
BookmarksFile is /home/kiril/.config/gqrx/bookmarks.csv
[INFO] [UHD] linux; GNU C++ version 8.2.1 20181127; Boost_106900; UHD_3.13.0.1-0-unknown
[INFO] Make connection: 'EVB7 (/dev/ttyACM0) [COM]'
[INFO] Device name: UNKNOWN
[INFO] Reference: -1e-06 MHz
^C
