Good evening,
I was testing the LimeSDR transmitter by transmitting a train of sinc pulses. However, I noticed that they follow a particular pattern along the train, varying their gain and phase, as you can see from the image screens below.
The first image is a close up of the pulses I’m transmitting:
The second image is a zoom out of the pulse train and you can see some sort of “modulation” that prevents the pulses from having a constant gain and phase, like I intended:
I’ve read the datasheet and the programming guide, and tested a few options but without sucess. Where exactly should I look to solve this problem? How can I transmit all the pulses with the same gain and phase?
OCB
