I am using the LMS7002EVB for an RF program but there is a little problem with the GUI operation. When I am going to tune the Tx baseband filter in the TBB tab, it always shows that the CSW_VCO_CGEN = 255 error. The bandwidth I type in is in the range. I try to adjust the VCO PARAM in the CLKGEN tab, but it cannot help. I also check the Rx baseband filter and it’s fine. It can be tuned.
Thank you for reply. My LimeSuiteGUI software is downloaded from www.limemicro.com last week. Does it has another source to get the latest software ? If it does, can you tell me.
The latest LimeSuiteGUI you sent me is work. It has solved my problem. Thanks a lot. But there is something that still confuses me. When I calculate and tune the CLK_H in the CLKGEN tab, it pops up such a warining:
You are using EVB board without Stream board. This is why you get these messages. Software tries to configure FPGA PLLs on the Stream board and throws the messages when it fails.
