I’m trying to use the tetrapol-tx.py on limesdr Mini
here is the project page
https://brmlab.cz/project/sdr/tetrapol/audio
next is the content of the tetrapol_tx.py
#!/usr/bin/env python2
-- coding: utf-8 --
GNU Radio Python Flow Graph
Title: TETRAPOL TX
Generated: Sat May 19 18:45:40 2018
from gnuradio import blocks
from gnuradio import digital
from gnuradio import eng_notation
from gnuradio import filter
from gnuradio import gr
from gnuradio.eng_option import eng_option
from gnuradio.filter import firdes
from optparse import OptionParser
import osmosdr
import time
class tetrapol_tx(gr.top_block):
def __init__(self, args="", freq=380000000, freq_offs=200000, in_file="", out_file="", oversample=10, ppm=0):
gr.top_block.__init__(self, "TETRAPOL TX")
# Parameters
self.args = args
self.freq = freq
self.freq_offs = freq_offs
self.in_file = in_file
self.out_file = out_file
self.oversample = oversample
self.ppm = ppm
# Variables
self.resample = resample = 32
self.samp_rate = samp_rate = 8000*oversample*resample
# Blocks
self.rational_resampler_xxx_0 = filter.rational_resampler_ccc(
interpolation=resample,
decimation=1,
taps=None,
fractional_bw=None,
self.osmosdr_sink_0 = osmosdr.sink( args="numchan=" + str(1) + " " + args )
self.osmosdr_sink_0.set_sample_rate(samp_rate)
self.osmosdr_sink_0.set_center_freq(freq+freq_offs, 0)
self.osmosdr_sink_0.set_freq_corr(ppm, 0)
self.osmosdr_sink_0.set_gain(10, 0)
self.osmosdr_sink_0.set_if_gain(20, 0)
self.osmosdr_sink_0.set_bb_gain(20, 0)
self.osmosdr_sink_0.set_antenna("", 0)
self.osmosdr_sink_0.set_bandwidth(1e6, 0)
self.freq_xlating_fir_filter_xxx_0 = filter.freq_xlating_fir_filter_ccc(1, (1, ), freq_offs, samp_rate)
self.digital_gmsk_mod_0 = digital.gmsk_mod(
samples_per_symbol=oversample,
bt=0.25,
verbose=False,
log=False,
self.blocks_pack_k_bits_bb_0 = blocks.pack_k_bits_bb(8)
self.blocks_multiply_const_vxx_1 = blocks.multiply_const_vcc((0.4, ))
self.blocks_file_source_0 = blocks.file_source(gr.sizeof_char*1, in_file, False)
# Connections
self.connect((self.blocks_file_source_0, 0), (self.blocks_pack_k_bits_bb_0, 0))
self.connect((self.blocks_multiply_const_vxx_1, 0), (self.osmosdr_sink_0, 0))
self.connect((self.blocks_pack_k_bits_bb_0, 0), (self.digital_gmsk_mod_0, 0))
self.connect((self.digital_gmsk_mod_0, 0), (self.rational_resampler_xxx_0, 0))
self.connect((self.freq_xlating_fir_filter_xxx_0, 0), (self.blocks_multiply_const_vxx_1, 0))
self.connect((self.rational_resampler_xxx_0, 0), (self.freq_xlating_fir_filter_xxx_0, 0))
def get_args(self):
return self.args
def set_args(self, args):
self.args = args
def get_freq(self):
return self.freq
def set_freq(self, freq):
self.freq = freq
self.osmosdr_sink_0.set_center_freq(self.freq+self.freq_offs, 0)
def get_freq_offs(self):
return self.freq_offs
def set_freq_offs(self, freq_offs):
self.freq_xlating_fir_filter_xxx_0.set_center_freq(self.freq_offs)
def get_in_file(self):
return self.in_file
def set_in_file(self, in_file):
self.blocks_file_source_0.open(self.in_file, False)
def get_out_file(self):
return self.out_file
def set_out_file(self, out_file):
def get_oversample(self):
return self.oversample
def set_oversample(self, oversample):
self.set_samp_rate(8000*self.oversample*self.resample)
def get_ppm(self):
return self.ppm
def set_ppm(self, ppm):
self.ppm = ppm
self.osmosdr_sink_0.set_freq_corr(self.ppm, 0)
def get_resample(self):
return self.resample
def set_resample(self, resample):
def get_samp_rate(self):
return self.samp_rate
def set_samp_rate(self, samp_rate):
self.osmosdr_sink_0.set_sample_rate(self.samp_rate)
def argument_parser():
parser = OptionParser(option_class=eng_option, usage="%prog: [options]")
parser.add_option(
“”, “–args”, dest=“args”, type=“string”, default="",
help=“Set osmosdr args [default=%default]”)
parser.add_option(
“-f”, “–freq”, dest=“freq”, type=“eng_float”, default=eng_notation.num_to_str(380000000),
help=“Set Frequency [default=%default]”)
parser.add_option(
“”, “–freq-offs”, dest=“freq_offs”, type=“intx”, default=200000,
help=“Set Freq offset [default=%default]”)
parser.add_option(
“-i”, “–in-file”, dest=“in_file”, type=“string”, default="",
help=“Set Input file name [default=%default]”)
parser.add_option(
“-o”, “–out-file”, dest=“out_file”, type=“string”, default="",
help=“Set Output file name [default=%default]”)
parser.add_option(
“”, “–oversample”, dest=“oversample”, type=“intx”, default=10,
help=“Set oversample [default=%default]”)
parser.add_option(
“”, “–ppm”, dest=“ppm”, type=“intx”, default=0,
help=“Set PPM [default=%default]”)
return parser
def main(top_block_cls=tetrapol_tx, options=None):
if options is None:
options, _ = argument_parser().parse_args()
tb = top_block_cls(args=options.args, freq=options.freq, freq_offs=options.freq_offs, in_file=options.in_file, out_file=options.out_file, oversample=options.oversample, ppm=options.ppm)
tb.start()
tb.wait()
if name == ‘main’:
main()
Here are error when trying to use this program with lime SDR MINI
Using Volk machine: avx2_64_mmx_orc
gr-osmosdr v0.1.4-98-gc653754d (0.1.5git) gnuradio 3.7.9
built-in sink types: hackrf soapy redpitaya file
[INFO] Make connection: 'LimeSDR Mini [USB 2.0] XXXXXXXXXXXXX
[INFO] Reference: 4e+07 MHz
[WARNING] TXLPF set to 5.000 MHz (requested 1.000 MHz [out of range]) --------> how to change
[ERROR] Tune Tx Filter: MCU error 14 (Tx RCAL_LPF range limit reached,) ---------> what to do ?
[ERROR] setBandwidth(Tx, 0, 1 MHz) Failed - ----------------> how to set ?
File “./tetrapol_tx.py”, line 182, in
main()
File “./tetrapol_tx.py”, line 176, in main
File “./tetrapol_tx.py”, line 60, in init
File “/usr/local/lib/python2.7/dist-packages/osmosdr/osmosdr_swig.py”, line 2194, in set_bandwidth
return _osmosdr_swig.sink_sptr_set_bandwidth(self, bandwidth, chan)
RuntimeError ----------------> ?
Any help would be nice
