Hello, Supporters,
When I changed the bandwidth of the RX filter under RBB tab on GUI, and saved a ini file with save button on GUI, then I closed the Limesuit GUI, reopened it again, and loaded the saved ini file , found the bandwidth of rx filter was not changed on GUI , Could you pls tell me the reason?
I listed my operation steps in the following.
1 Power on the board, open the Limesuit and setup connection
2 Load a ini file with open button on GUI.
3 Change the rx filter bandwidth and tune under RBB tab
4 Save an ini file with save button on GUI
5 Close Limesuit GUI and reopen it
6 Recuild connection
7 Load the ini file saved in step 4
8 Verify the bandwidth, found the bandwidth was not changed.
@ricardas @Zydrunas Tamosevicius
Thanks!
