I share with you a SingleRx program with some modifications to see the behavior of the FIFO and the reception.
If I put a time delay I see that I do not have the right bit rate, if I remove the time delay, the average bit rate calculated with the sum of the samples received at the user level and the time between the start of the streamer and the end of program is ok.
In the case where the flow is kb, I observe that the fifo is always almost full and an overrun variable other than 0.
Question:
- What
matches overrun?
- How to ensure that there is no loss of samples?
Thank you
@file singleRX.cpp
@author Lime Microsystems (www.limemicro.com)
@brief RX example
//#define USE_GNU_PLOT = 1
#include “lime/LimeSuite.h”
#include
#include
#ifdef USE_GNU_PLOT
#include “gnuPlotPipe.h”
#endif
#include
#include <unistd.h>
#include <time.h>
#include <stdio.h>
using namespace std;
lms_device_t* device = NULL;
int error()
if (device != NULL)
LMS_Close(device);
exit(-1);
double GetTickcount(void);
//Find devices
//First we find number of devices, then allocate large enough list, and then populate the list
int n;
if ((n = LMS_GetDeviceList(NULL)) < 0)//Pass NULL to only obtain number of devices
error();
cout << "Devices found: " << n << endl;
if (n < 1)
return -1;
lms_info_str_t* list = new lms_info_str_t[n]; //allocate device list
if (LMS_GetDeviceList(list) < 0) //Populate device list
error();
for (int i = 0; i < n; i++) //print device list
cout << i << ": " << list[i] << endl;
cout << endl;
//Open the first device
error();
delete [] list; //free device list
//Use LMS_LoadConfig(device, "/path/to/file.ini") to load config from INI
if (LMS_Init(device) != 0)
error();
//Enable RX channel
//Channels are numbered starting at 0
error();
//Set center frequency to 800 MHz
if (LMS_SetLOFrequency(device, LMS_CH_RX, 0, 800e6) != 0)
error();
//print currently set center frequency
float_type freq;
if (LMS_GetLOFrequency(device, LMS_CH_RX, 0, &freq) != 0)
error();
cout << "\nCenter frequency: " << freq / 1e6 << " MHz\n";
//select antenna port
lms_name_t antenna_list[10]; //large enough list for antenna names.
//Alternatively, NULL can be passed to LMS_GetAntennaList() to obtain number of antennae
if ((n = LMS_GetAntennaList(device, LMS_CH_RX, 0, antenna_list)) < 0)
error();
cout << "Available antennae:\n"; //print available antennae names
cout << i << ": " << antenna_list[i] << endl;
if ((n = LMS_GetAntenna(device, LMS_CH_RX, 0)) < 0) //get currently selected antenna index
error();
//print antenna index and name
cout << "Automatically selected antenna: " << n << ": " << antenna_list[n] << endl;
if (LMS_SetAntenna(device, LMS_CH_RX, 0, LMS_PATH_LNAW) != 0) // manually select antenna
error();
error();
cout << "Manually selected antenna: " << n << ": " << antenna_list[n] << endl;
//Set sample rate to 1 MHz, preferred oversampling in RF 8x
//This set sampling rate for all channels
if (LMS_SetSampleRate(device, 1e6, 8) != 0)
error();
//print resulting sampling rates (interface to host , and ADC)
float_type rate, rf_rate;
if (LMS_GetSampleRate(device, LMS_CH_RX, 0, &rate, &rf_rate) != 0) //NULL can be passed
error();
cout << "\nHost interface sample rate: " << rate / 1e6 << " MHz\nRF ADC sample rate: " << rf_rate / 1e6 << "MHz\n\n";
//Example of getting allowed parameter value range
//There are also functions to get other parameter ranges (check LimeSuite.h)
//Get allowed LPF bandwidth range
lms_range_t range;
if (LMS_GetLPFBWRange(device,LMS_CH_RX,&range)!=0)
error();
cout << "RX LPF bandwitdh range: " << range.min / 1e6 << " - " << range.max / 1e6 << " MHz\n\n";
//Configure LPF, bandwidth 8 MHz
if (LMS_SetLPFBW(device, LMS_CH_RX, 0, 8e6) != 0)
error();
//Set RX gain
if (LMS_SetNormalizedGain(device, LMS_CH_RX, 0, 0.7) != 0)
error();
//Print RX gain
float_type gain; //normalized gain
if (LMS_GetNormalizedGain(device, LMS_CH_RX, 0, &gain) != 0)
error();
cout << "Normalized RX Gain: " << gain << endl;
unsigned int gaindB; //gain in dB
if (LMS_GetGaindB(device, LMS_CH_RX, 0, &gaindB) != 0)
error();
cout << "RX Gain: " << gaindB << " dB" << endl;
//Perform automatic calibration
if (LMS_Calibrate(device, LMS_CH_RX, 0, 8e6, 0) != 0)
error();
//Enable test signal generation
//To receive data from RF, remove this line or change signal to LMS_TESTSIG_NONE
if (LMS_SetTestSignal(device, LMS_CH_RX, 0, LMS_TESTSIG_NCODIV4, 0, 0) != 0)
error();
//Streaming Setup
//Initialize stream
lms_stream_t streamId;
streamId.channel = 0; //channel number
streamId.fifoSize = 1024 * 1024; //fifo size in samples
streamId.throughputVsLatency = 1.0; //optimize for max throughput
streamId.isTx = false; //RX channel
streamId.dataFmt = lms_stream_t::LMS_FMT_F32; //32-bit floats
if (LMS_SetupStream(device, &streamId) != 0)
error();
//Data buffers
const int bufersize = 10000; //complex samples per buffer
float buffer[bufersize * 2]; //must hold I+Q values of each sample
//Start streaming
float startTick;
lms_stream_status_t status;
int samplesRead;
int nb_samplesRead =0;
LMS_GetStreamStatus(&streamId, &status);
cout << "timestamp avant start: " << status.timestamp << endl; ;
cout << "fifoFilledCount: " << status.fifoFilledCount << endl; ;
startTick = GetTickcount() ;
LMS_StartStream(&streamId);
cout << "timestamp après start lecture: " << status.timestamp << endl; ;
#ifdef USE_GNU_PLOT
GNUPlotPipe gp;
gp.write(“set size square\n set xrange[-1:1]\n set yrange[-1:1]\n”);
#endif
float startTickCount, transferTime_sec;
auto t2 = t1;
while (chrono::high_resolution_clock::now() - t1 < chrono::seconds(10)) //run for 10 seconds
cout << "timestamp avant lecture: " << status.timestamp << endl; ;
samplesRead = LMS_RecvStream(&streamId, buffer, bufersize, NULL, 1000);
nb_samplesRead = nb_samplesRead + samplesRead;
cout << "samplesRead : " << samplesRead << endl;
cout << "timestamp apres lecture: " << status.timestamp << endl; ;
#ifdef USE_GNU_PLOT
gp.write(“plot ‘-’ with points\n”);
for (int j = 0; j < samplesRead; ++j)
gp.writef("%f %f\n", buffer[2 * j], buffer[2 * j + 1]);
gp.write(“e\n”);
gp.flush();
//Receive samples
cout << "timestamp gnu plot: " << status.timestamp << endl; ;
cout << "droppedPackets: " << status.droppedPackets << endl; ;
cout << "overrun: " << status.overrun << endl; ;
//cout << "RX fifo: " << 100 * status.fifoFilledCount / status.fifoSize << “%” << endl; //percentage of FIFO filled
#endif
startTickCount = GetTickcount() ;
usleep(1e5);
transferTime_sec = (GetTickcount() - startTickCount) ;
cout << "time : " << transferTime_sec/1000 << endl; ;
//Receive samples
cout << "timestamp 2: " << status.timestamp << endl; ;
//Get stream status
//I and Q samples are interleaved in buffer: IQIQIQ...
INSERT CODE FOR PROCESSING RECEIVED SAMPLES
//Print stats (once per second)
//Plot samples
//Get stream status
cout << "RX data rate: " << status.linkRate / 1e6 << " MB/s\n"; //link data rate
cout << "RX fifo: " << 100 * status.fifoFilledCount / status.fifoSize << "%" << endl; //percentage of FIFO filled
cout << "nb_samplesRead: " << nb_samplesRead << endl;
transferTime_sec = (GetTickcount() - startTick) /1000;
cout << "transferTime_sec: " << transferTime_sec << endl;
cout << "debit: " << nb_samplesRead*2*2/transferTime_sec/1e6 << "Mbytes/s" << endl;
//Stop streaming
LMS_StopStream(&streamId); //stream is stopped but can be started again with LMS_StartStream()
LMS_DestroyStream(device, &streamId); //stream is deallocated and can no longer be used
//Close device
LMS_Close(device);
return 0;
struct timespec now;
if (clock_gettime(CLOCK_MONOTONIC, &now))
return 0;
return now.tv_sec*1000.0+now.tv_nsec/1000000.0;
