Can gr-osmocom be used for simultaneously accessing both RX1 and RX2 on LimeUSB when using gr-osmocom remotely through Soapy? If so, what is the correct string to enter into gr-osmocom. If not, can gr-limesdr be used, and how.
No idea about gr-osmocom and since you’re talking about using this with SoapyRemote, you could always ask in the Pothos community.
gr-limesdr uses the LMS API directly and so since there is no SoapySDR in the middle, you wouldn’t be able to use this remotely. @Garmus could advise regarding the dual channel support.
