Hi all, I am doing a course project that requires analyzing a wireless protocol. To get started, I tried sniffing the ambient wireless spectrum to see if my board and toolchain were working. The following sequence of experiments has led me to believe my board is defective, but I do not have enough experience to tell for sure.
I installed
LimeSuitefromapton aubuntu 20.04machine and usedQSpectrumAnalyzerto record signals in the wifi range. This returned very low signal strengths in the low-130db’s. After turning up the gain, the best I could get was-128dbor so.
Fine, so I thought, perhaps the radio needed calibration. But using
LimeSuiteGUIto calibrate, I got intermittent errors. Sometimes the error wasRX Calibration Failed: MCU error 5 (Loopback signal weak: not connected/insufficient gain?). Other times it would beRX Calibration Failed: MCU error 3 (SXR tune failed). And once in a while, the calibration would go through if I unplug/replug the device.This led me to believe the board might be defective. So I ran
LimeQuickTestand got the following failures:[ TESTING STARTED ] ->Start time: Thu Oct 10 21:03:22 2024 ->LimeSuite version: 22.09.1-myriadrf1~ubuntu20.04 ->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1DA1766B71575F, HW=7, GW=2.6 Serial Number: 1DA1766B71575F Chip temperature: 45 C [ Clock Network Test ] ->REF clock test Test results: 17345; 18889; 20371 - PASSED ->VCTCXO test Results : 6711030 (min); 6711064 (max) - FAILED FAILED ->Clock Network Test FAILED [ FPGA EEPROM Test ] ->Read EEPROM Operation failed: error code 5 ->FPGA EEPROM Test FAILED [ LMS7002M Test ] ->Perform Registers Test ->External Reset line test Reg 0x20: Write value 0xFFFD, Read value 0xFFFD Reg 0x20: value after reset 0x0FFFF ->LMS7002M Test PASSED [ RF Loopback Test ] ->Configure LMS ->Run Tests (TX_2 -> LNA_W): CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-27.2 dBFS, 5.00 MHz) - FAILED ->Run Tests (TX_1 -> LNA_H): CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-25.1 dBFS, 5.00 MHz) - FAILED ->RF Loopback Test FAILED => Board tests FAILED <= Elapsed time: 1.36 secondsThe
EEPROMfailure was suspicious, and theRF Loopback Testseemed to confirm that something was wrong with the RX of the board. -
Finally, just for completeness, I also tried
Universal Radio Hackerand it was not able to read from the board, albeit successfully opening the stream.[INFO::settings.py::get_receive_buffer_size] Allocate receive buffer with 262.144KB [INFO::Device.py::start_rx_mode] LimeSDR: Starting RX Mode Reference clock 40.00 MHz [INFO::Device.py::log_retcode] LimeSDR-OPEN (LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1DA1766B71575F): Success [INFO::Device.py::log_retcode] LimeSDR-INIT: Success [INFO::Device.py::log_retcode] LimeSDR-SET_CHANNEL_INDEX to 0: Success [INFO::Device.py::log_retcode] LimeSDR-SET_ANTENNA_INDEX to 2: Success [INFO::Device.py::log_retcode] LimeSDR-SET_FREQUENCY to 433.92M: Success [INFO::Device.py::log_retcode] LimeSDR-SET_SAMPLE_RATE to 2M: Success RX LPF configured [INFO::Device.py::log_retcode] LimeSDR-SET_BANDWIDTH to 2M: Success [INFO::Device.py::log_retcode] LimeSDR-SET_RF_GAIN to 0.25: Success [INFO::Device.py::log_retcode] LimeSDR-Initialize stream: Success [WARNING::LimeSDR.py::receive_sync] LimeSDR: Failed to receive stream -
I also tried the above on a Mac to see if the errors were machine/OS dependent. Unfortunately, I got the same result. Any help is greatly appreciated!
