theboel, thank you. I haven’t change any config of default srslte. the soapysdr version is 0.8.0, Lime suite version is 20.07
I can see my limesdr mini info with SoapySDRUtil -find command
link@up2ubuntu1604:~/LimeSuite/build$ SoapySDRUtil --info
Lib Version: v0.8.0-g580b94f3
API Version: v0.8.0
ABI Version: v0.8
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.8
Module found: /usr/local/lib/SoapySDR/modules0.8/libLMS7Support.so (20.07.2-9526621)
Available factories… lime
Available converters…
- CS32 -> [CS32]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- S32 -> [S32]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
link@up2ubuntu1604:~/LimeSuite/build$ LimeUtil --info
LimeSuite information summary
Version information:
Library version: v20.07.2-g9526621f
Build timestamp: 2020-09-20
Interface version: v2020.7.2
Binary interface: 20.07-1
System resources:
Installation root: /usr/local
User home directory: /home/link
App data directory: /home/link/.local/share/LimeSuite
Config directory: /home/link/.limesuite
Image search paths:
- /home/link/.local/share/LimeSuite/images
Supported connections:
------------------------------------------------- below is the crash issue:
link@up2ubuntu1604:~/srsLTE/build/lib/examples$ ./pdsch_enodeb
linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_003.010.003.000-0-g423b4c19
Opening RF device…
Opening USRP channels=1, args:
/home/link/srsLTE/lib/src/phy/rf/rf_uhd_imp.c.187: Error opening UHD: code 11
Soapy has found device #0: addr=24607:1027, driver=lime, label=LimeSDR Mini [USB 3.0] 1D58829B24378A, media=USB 3.0, module=FT601, name=LimeSDR Mini, serial=1D58829B24378A,
Selecting Soapy device: 0
[INFO] Make connection: ‘LimeSDR Mini [USB 3.0] 1D58829B24378A’
srsLTE crashed… backtrace saved in ‘./srsLTE.backtrace.crash’…
— exiting —
------------------------------------------------- below is the log of crash issue:
— command=’./pdsch_enodeb’ version=20.04.2 signal=4 date=‘20/09/2020 11:31:57’ —
./pdsch_enodeb() [0x49f06e]
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f17f6eb14b0]
/usr/local/lib/libLimeSuite.so.18.03-1(_ZN4lime8LMS7002MC2Ev+0x67) [0x7f17f08f6547]
/usr/local/lib/libLimeSuite.so.18.03-1(ZN4lime11LMS7_DeviceC2EPS0+0x1ee) [0x7f17f093144e]
/usr/local/lib/libLimeSuite.so.18.03-1(+0x780bd) [0x7f17f09340bd]
/usr/local/lib/libLimeSuite.so.18.03-1(ZN4lime11LMS7_Device12CreateDeviceERKNS_16ConnectionHandleEPS0+0x1bb) [0x7f17f092bcdb]
/usr/local/lib/SoapySDR/modules0.6/libLMS7Support.so(+0x1227b) [0x7f17f0b9527b]
/usr/local/lib/SoapySDR/modules0.6/libLMS7Support.so(+0x7c46) [0x7f17f0b8ac46]
/usr/lib/x86_64-linux-gnu/libSoapySDR.so.0.6(_ZN8SoapySDR6Device4makeERKSt3mapINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEES7_St4lessIS7_ESaISt4pairIKS7_S7_EEE+0xc7a) [0x7f17f606349a]
/usr/lib/x86_64-linux-gnu/libSoapySDR.so.0.6(SoapySDRDevice_make+0x203) [0x7f17f607bf43]
/home/link/srsLTE/build/lib/src/phy/rf/libsrslte_rf.so(rf_soapy_open_multi+0x40e) [0x7f17f80448ee]
/home/link/srsLTE/build/lib/src/phy/rf/libsrslte_rf.so(srslte_rf_open_devname+0xa9) [0x7f17f803e529]
./pdsch_enodeb() [0x40c38c]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f17f6e9c830]
./pdsch_enodeb(_start+0x29) [0x40d1c9]
