OpenUSRP
root@debian:~/OpenUSRP/build# cd …
root@debian:~/OpenUSRP# rm -rf build
root@debian:~/OpenUSRP# mkdir build && cd build && cmake …
– The CXX compiler identification is GNU 6.3.0
– The C compiler identification is GNU 6.3.0
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Build type not specified: defaulting to release.
– Found PkgConfig: /usr/bin/pkg-config (found version “0.29”)
– Checking for module ‘uhd’
– Found uhd, version 003.009.005-0-unknown
– Found UHD: /usr/lib/i386-linux-gnu/libuhd.so
– UHD root directory: /usr
– UHD include directories: /usr/include
– UHD libraries: /usr/lib/i386-linux-gnu/libuhd.so
– Checking uhd::device::register_device() API…
– Reading /usr/include/uhd/device.hpp…
– has filter API
– Checking uhd::property::set_publisher() API…
– Reading /usr/include/uhd/property_tree.hpp…
– missing set_publisher() API
– Found LIMESUITE: /usr/local/lib/libLimeSuite.so
– LimeSuite include directories: /usr/local/include/lime
– LimeSuite libraries: /usr/local/lib/libLimeSuite.so
– Configuring Boost C++ Libraries…
– Looking for pthread.h
– Looking for pthread.h - found
– Looking for pthread_create
– Looking for pthread_create - not found
– Looking for pthread_create in pthreads
– Looking for pthread_create in pthreads - not found
– Looking for pthread_create in pthread - found
– Found Threads: TRUE
– Boost version: 1.62.0
– Found the following Boost libraries:
– thread
– system
– atomic
– chrono
– date_time
– Boost include directories: /usr/include
– Boost library directories: /usr/lib/i386-linux-gnu
– Boost libraries: /usr/lib/i386-linux-gnu/libboost_thread.so;/usr/lib/i386-linux-gnu/libboost_system.so;/usr/lib/i386-linux-gnu/libboost_atomic.so;/usr/lib/i386-linux-gnu/libboost_chrono.so;/usr/lib/i386-linux-gnu/libboost_date_time.so;/usr/lib/i386-linux-gnu/libpthread.so
– Configuring done
– Generating done
– Build files have been written to: /root/OpenUSRP/build
root@debian:~/OpenUSRP/build# ls
CMakeCache.txt CMakeFiles cmake_install.cmake CTestTestfile.cmake Makefile
root@debian:~/OpenUSRP/build# make
Scanning dependencies of target OpenUSRP
[ 33%] Building CXX object CMakeFiles/OpenUSRP.dir/limesdr_impl.cpp.o
/root/OpenUSRP/limesdr_impl.cpp: In constructor ‘limesdr_impl::limesdr_impl(const lime::ConnectionHandle&, const uhd::device_addr_t&)’:
/root/OpenUSRP/limesdr_impl.cpp:127:34: error: ‘const struct lime::DeviceInfo’ has no member named ‘addrsLMS7002M’
const size_t numRFICs = devInfo.addrsLMS7002M.size();
CMakeFiles/OpenUSRP.dir/build.make:62: recipe for target ‘CMakeFiles/OpenUSRP.dir/limesdr_impl.cpp.o’ failed
make[2]: *** [CMakeFiles/OpenUSRP.dir/limesdr_impl.cpp.o] Error 1
CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/OpenUSRP.dir/all’ failed
make[1]: *** [CMakeFiles/OpenUSRP.dir/all] Error 2
Makefile:138: recipe for target ‘all’ failed
make: *** [all] Error 2
And this:
root@debian:~/OpenUSRP/build# which SoapySDR
root@debian:~/OpenUSRP/build# whereis SoapySDR
SoapySDR: /usr/local/lib/SoapySDR /usr/include/SoapySDR
root@debian:~/OpenUSRP/build# whereis SoapyUHD
SoapyUHD:
root@debian:~/OpenUSRP/build# whereis uhd
uhd: /usr/lib/uhd /usr/include/uhd.h /usr/include/uhd
root@debian:~/OpenUSRP/build# uhd --version
-su: uhd: command not found
root@debian:~/OpenUSRP/build# SoapyUHD --version
-su: SoapyUHD: command not found
root@debian:~/OpenUSRP/build# SoapyUHD -^C
root@debian:~/OpenUSRP/build# LimeUtil --find
- [LimeSDR Mini, media=USB 2.0, module=FT601, addr=xserial=x]
root@debian:~/OpenUSRP/build# uhd_find_devices
linux; GNU C++ version 6.3.0 20170221; Boost_106200; UHD_003.009.005-0-unknown
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
RtApiAlsa::getDeviceInfo: snd_pcm_open error for device (hw:0,0), Device or resource busy.
– UHD Device 0
Device Address:
default_input: True
default_output: False
device_id: 0
driver: audio
label: hw:HDA Intel PCH,0
type: soapy
– UHD Device 1
Device Address:
default_input: False
device_id: 4
driver: audio
label: default
type: soapy
– UHD Device 2
Device Address:
addr: x
driver: lime
media: USB
module: uLimeSDR
name: USB 2.0 (LimeSDR Mini)
type: soapy
SoapyUHD
:1 (INCLUDE_SUBDIRECTORY):
Unknown CMake command “INCLUDE_SUBDIRECTORY”.
CMake Warning (dev) in CMakeLists.txt:
No cmake_minimum_required command is present. A line of code such as
cmake_minimum_required(VERSION 3.7)
should be added at the top of the file. The version specified may be lower
if you wish to support older CMake versions for this project. For more
information run “cmake --help-policy CMP0000”.
This warning is for project developers. Use -Wno-dev to suppress it.
– Configuring incomplete, errors occurred!
