So we use Soapy APIs to implement basic radar. Specifically, we separate Transmitting and Receiving.
Followings are codes of them:
#define CONTIGUOUS_BUFF_TX_LENGTH (int) 2e5
#define BUFF_TX_LENGTH (size_t) 1e3
#define BUFF_RX_LENGTH (size_t) 1e3
#define STREAM_TIMEOUT_TX 3e6
#define STREAM_TIMEOUT_RX 3e6
#define ZERO_DELAY_SAMPLES 96
//Begin transmitting
int txStreamStatus = 0, rxStreamStatus = 0;
for(int i = 0; i < CONTIGUOUS_BUFF_TX_LENGTH / BUFF_TX_LENGTH; i++)
buffsTx[0] = bufferTx;
txStreamStatus = SoapySDRDevice_writeStream(sdr, txStream, buffsTx, BUFF_TX_LENGTH, &flags, transmitTime, STREAM_TIMEOUT_TX);
transmitTime += BUFF_TX_LENGTH / SAMPLE_RATE_TX * 1e9; //Begin next transmission immediately after this one finishes.
bufferTx += BUFF_TX_LENGTH; //Move buffer pointer to the next section of the contiguous buffer to be transmitted.
if(txStreamStatus != BUFF_TX_LENGTH)
printf("[TransmitReceive] Write stream failed: %d\n", txStreamStatus);
// //Begin receiving
for(int i = 0; i < CONTIGUOUS_BUFF_RX_LENGTH / BUFF_RX_LENGTH; i++)
buffsRx[0] = bufferRx;
rxStreamStatus = SoapySDRDevice_readStream(sdr, rxStream, buffsRx, BUFF_RX_LENGTH, &flags, ×tampRx, STREAM_TIMEOUT_RX);
bufferRx += BUFF_RX_LENGTH; //Move buffer pointer to the next section of the contiguous buffer to be received.
if(rxStreamStatus != BUFF_RX_LENGTH)
printf("[TransmitReceive] Samples captured: %d\n", rxStreamStatus);
if(rxStreamStatus < 0)
printf("[TransmitReceive] Read stream failed. Error Code: %d\n", rxStreamStatus);
*firstSampleIndex = BUFF_RX_LENGTH - rxStreamStatus + ZERO_DELAY_SAMPLES;
if(rxStreamStatus < 0) // Detect a failed chirp
printf("[TransmitReceive] Detected failed chirp! Filling buffer with zeros.\n");
for(int j = 0; j < CONTIGUOUS_BUFF_RX_LENGTH; j++)
// contBufferRx[j] = 0*(1+I);
contBufferRx[j].real = 0;
contBufferRx[j].imag = 0;
break; // Skip this chirp, move on to the next one.
So the flow is:
- We set up stream first =>
SoapySDRStream* stream = SoapySDRDevice_setupStream(sdr, direction, SOAPY_SDR_CS16, NULL, 0, &args) - Once RX and TX stream are set, we put the samples in the buffer.
- We then activate both the streams. =>
SoapySDRDevice_activateStream(sdr, txStream, 0, 0, 0)andSoapySDRDevice_activateStream(sdr, rxStream, flags, receiveTime, 0)
A part of the outputs is like this:
Started chirp code at time 8.742012 s
[TransmitReceive] Scheduled to transmit/receive a chirp at 9.025904 s
[TransmitReceive] Samples captured: 420
[SaveData] Saving data to file...
Finished chirp code at time 9.045836 s
The return value of SoapySDRDevice_readStream() is the number of elements read per buffer or error code. What I’m confused about, from receiving part of code:
why are some Samples lost?
Is this a bug where I could solve or just improve the lost rate?
