My use case is to make occasional parallel captures of certain duration from two Rx inputs, but I found out that this glitch happens when using one input as well.
The working cycle is as follows:
Init Lime board for 2 channels;
SetupRXStream x N, where N can be 1 or 2;
do {
StartStream x N;
receive TargetSampleCnt samples;
StopStream x N;
} wihle (getchar() != 'q')
DestroyStream x N;
Close Lime board.
I receive the stream blockwise using a buffer of 50000 samples, at Fs = 5, 10, 20, 40 or 80 MSps. After each received block I call LMS_GetStreamStatus and if it indicates drops, log them to the screen. My setup can sustain 2x40 or 1x80 MSps streams freely for up to 5 secs for sure (and I think more, just didn’t try), except for the very first block of each Start/StopStream cycle.
I tried various combinations of Fs, oversampling and data format mode values, and built a small table which illustrates the case (oversampling seems not to have effect on this):
for FMT_I12:
MSps Pkts lost T drop start, mcs
2x40 (or 1x80) ~160 187
2x20 (or 1x40) 15-50 374
2x10 0-8 748
2x5 0-5 1495
for FMT_I16 I checked two variants:
2x20 (or 1x40) 20-70 280
, which corresponds to the I12 case accounting that 280 ~= 3/4 * 374, so I didn’t try further.
So, these losses occur approx. at 14950 sample from the beginning of the stream, but their count differs from time to time. The pity is that it obviously isn’t caused by overall system throughput barrier, as it happens even at 10 MSps.
I encountered a glitch like this previously, when it happened stable at 1.5 ms after stream start, but then found out that it was caused by MS VS debugger (I use MS VC++ 2013). So, free run w/o debugger attached solved that. But in this case I tried to eliminate all reasons that I could imagine, running release version from cmd prompt, switched off my disk writing routines, etc. It’s very stable.
Of course, knowing that it’s to high degree “fixed”, I can just throw out first samples, but I don’t like such solutions and hope that it can be overcome some apropriate way…
