Looking at the Min Schematic I see that the TX output is switched between TX1_1 and TX1_2 using a skyworks switch controlled by FPGA bank 8. Does this happen automatically when you select the transmit frequency or do you have to
manually do the switching via the API. I know you have to select TX1_1 or TX1_2 as your output, is this enough to select the right skyworks switch combination to route the signal to the transmit SMA?
