I just got my LimeSDR and now I want to play with it.
I use the latest sources of LimeSuite and SoapySDR. But while trying some example I noticed that sometimes an error “setBandwidth failed” occur, which disappear after disconnecting the USB-Port and connecting it again.
I use the following components:
- Linux (Ubuntu 16.04) with 4.10.0-37 Kernel
- libusb 1.12-28
- LimeSuite v17.10.0 and also master (78122ec) tested
- SoapySDR master (ba9ad2d)
To simplify the issue I try to use SoapSDRUtil and set the Bandwidth. Sometimes it worked, but quiet often the following occur:
SoapySDRUtil --rate=10000000 --direction=RX
[INFO] Make connection: 'LimeSDR-USB [USB 3.0] 9070105C61E23'
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
[INFO] Ver=7, Rev=1, Mask=1
[ERROR]
[ERROR] setBandwidth(Rx, 0, 30 MHz) Failed -
Error in rate test:
terminate called after throwing an instance of 'std::runtime_error'
what(): SoapySDR::Device::unmake() unknown device
Abgebrochen (Speicherabzug geschrieben)
The setting of bandwidth failed without any further error message. But more weired is, that the gateware could be found if I try again:
Expected gateware version 2, revision 11
[INFO] Ver=0, Rev=0, Mask=0
Error in rate test: ResetChip() failed
When I disconnect Lime’s USB interface and connect it again, the most times it work again (sometimes I need to reconnect twice):
Stream format: CS16
Num channels: 1
Element size: 4 bytes
Begin RX rate test at 10 Msps
Starting stream loop, press Ctrl+C to exit...
|[INFO] L
9.48016 Msps 37.9206 MBps
9.74007 Msps 38.9603 MBps
What could be the root cause of the issue?
Thank you in advance.
Br,
Sebastian
