referring to the LMS7002M internal block diagram here: https://myriadrf.org/news/limesdr-made-simple-part-2-matching-lms7002m-rx-iq/, i have a question:
In the transmit side, on the right hand side of the figure, it can be clearly seen that there are two paths in each channel. Each path separately goes into a DAC each, and the following components. Clearly these are the digital signals I and Q corresponding to a frequency Wosc(the TXmix frequency).
But when you generate a signal in MATLAB and export it to LimeSDR using the command :
LMS_SendStream, in the "samples " buffer, how is I and Q data placed?
Is it like: samples = I + jQ or is it like samples = [I Q]…or some other way?
Basically does the baseband processor seperate the samples signal above into 2 independent data paths called I path and Q path?
remember, all this is in MATLAB.
Thanks
