SDRAngel does not work with LimeSDR Mini 2.0
Hello all,
Could anyone please help with this?
SDRAngel does not work with the LimeSDR Mini 2.0, although it identifies it, but when you press play, it does not play sound and does not show a waterfall.
There are also errors:
  1. red if underruns
  2. red if calibration failed
Thank you!
It looks like antenna symbol shows ‘No’, try to select a connected antenna
Hello!
Thanks for your answer.
When trying to change the antennas to other ones, everything is the same, nothing happens and the SDRAngel does not work.
I can’t use it directly either.
But on my m1 macbook it can be used with soapy. You just have to start it manually from the terminal.
sdrangel --soapy
