I eagerly expect to make gr-gsm work thoroughly on my limeSDR-Mini.
So I checked this
and the project that was mentioned in this topic
I found something that inspired me!
It seems that this project can only make grgsm_scanner available on limeSDR with gr-limesdr support until now.
I speculate that these following scripts in class wideband_scanner are decisive:
in constructor __init__
self.rtlsdr_source = limesdr.source("", 0, "")
self.rtlsdr_source.set_sample_rate(sample_rate)
self.rtlsdr_source.set_center_freq(carrier_frequency - 0.1e6, 0)
self.rtlsdr_source.set_bandwidth(sample_rate,0)
self.rtlsdr_source.set_gain(int(gain),0)
in method set_carrier_frequency
def set_carrier_frequency(self, carrier_frequency):
self.carrier_frequency = carrier_frequency
self.rtlsdr_source.set_rf_freq(carrier_frequency - 0.1e6, 0)
I compared this file with the original one at
and found that the source seems to be initialized by these scripts
self.rtlsdr_source = osmosdr.source(args="numchan=" + str(1) + " " +
str(grgsm.device.get_default_args(args)))
self.rtlsdr_source.set_freq_corr(ppm, 0)
self.rtlsdr_source.set_dc_offset_mode(2, 0)
self.rtlsdr_source.set_iq_balance_mode(0, 0)
self.rtlsdr_source.set_gain_mode(True, 0)
self.rtlsdr_source.set_bandwidth(sample_rate, 0)
self.rtlsdr_source.set_gain(gain, 0)
self.rtlsdr_source.set_if_gain(32, 0)
self.rtlsdr_source.set_bb_gain(30, 0)
I hope to get answers to these two questions:
1. The difference between set_rf_freq() and set_center_freq() in gr-limesdr, and what they do.
2. For other functions using source blocks in gr-gsm like
https://gitlab.com/myriadrf/gr-gsm/-/blob/master/apps/helpers/grgsm_capture
they also have similar scripts such as
self.rtlsdr_source = osmosdr.source( args="numchan=" + str(1) + " " + args )
self.rtlsdr_source.set_sample_rate(samp_rate)
self.rtlsdr_source.set_center_freq(fc - shiftoff, 0)
self.rtlsdr_source.set_iq_balance_mode(2, 0)
self.rtlsdr_source.set_if_gain(20, 0)
self.rtlsdr_source.set_bb_gain(20, 0)
self.rtlsdr_source.set_antenna("", 0)
self.rtlsdr_source.set_bandwidth(250e3+abs(shiftoff), 0)
