I have been trying to run a flowgraph on grc and even the drivers are correctly installed and caching disabled I get the same error. GRC doesnt see limesdr. Any ideas?
Your log clearly shows that cache is used: "[INFO] LMS7002M calibration values caching Enable"
, "SetFrequency using cache values..."
, also judging from the error message you are not using the latest version.
Delete the cache file from /home/pi/.limesuite
, or update LimeSuite to latest version
I deleted cache but it makes automatically even the caching is disabled. GW is updated to 16 but nothing has changed.
