Datasheet provides list of frequency ranges for each RF port it is optimized for. It means that you will get best result if you use particular RF port in supported range. But everything depends on RF matching network. RF matching network may be optimized for 900 MHz for instance and connected to any RF Rx input of LMS7002M. Hence the matching network defines frequency ranges.
So, for LimeSDR-USB Rx RF inputs are optimized for these frequencies (it doesn’t mean it will not work at out of range frequencies, but performance will be lower):
LNAL: 700MHz - 900MHz
LNAH: 2GHz - 2.6GHz
LNAW: 700MHz - 2.6GHz
