hi, i am new to RF i am trying to receive AM signal from signal generator by using limesdrmini with the basicRX code,which i am attached below…but i am not getting it. should i add any extra logic here.?and should i change the buffer format?
#include “lime/LimeSuite.h”
#include
#include
#ifdef USE_GNU_PLOT
#include “gnuPlotPipe.h”
#endif
using namespace std;
lms_device_t* device = NULL;
int error()
if (device != NULL)
LMS_Close(device);
exit(-1);
//Find devices
int n;
lms_info_str_t list[8]; //should be large enough to hold all detected devices
if ((n = LMS_GetDeviceList(list)) < 0) //NULL can be passed to only get number of devices
error();
cout << "Devices found: " << n << endl; //print number of devices
if (n < 1)
return -1;
//open the first device
error();
//Use LMS_LoadConfig(device, "/path/to/file.ini") to load config from INI
if (LMS_Init(device) != 0)
error();
//Enable RX channel
//Channels are numbered starting at 0
error();
//Set center frequency to 800 MHz
if (LMS_SetLOFrequency(device, LMS_CH_RX, 0, 800e6) != 0)
error();
//Set sample rate to 8 MHz, ask to use 2x oversampling in RF
//This set sampling rate for all channels
if (LMS_SetSampleRate(device, 8e6, 2) != 0)
error();
//Enable test signal generation
//To receive data from RF, remove this line or change signal to LMS_TESTSIG_NONE
if (LMS_SetTestSignal(device, LMS_CH_RX, 0, LMS_TESTSIG_NONE, 0, 0) != 0)
error();
//Streaming Setup
//Initialize stream
lms_stream_t streamId; //stream structure
streamId.channel = 0; //channel number
streamId.fifoSize = 1024 * 1024; //fifo size in samples
streamId.throughputVsLatency = 1.0; //optimize for max throughput
streamId.isTx = false; //RX channel
streamId.dataFmt = lms_stream_t::LMS_FMT_I12; //12-bit integers
if (LMS_SetupStream(device, &streamId) != 0)
error();
//Initialize data buffers
const int sampleCnt = 5000; //complex samples per buffer
int16_t buffer[sampleCnt * 2]; //buffer to hold complex values (2*samples))
//Start streaming
LMS_StartStream(&streamId);
//Streaming
#ifdef USE_GNU_PLOT
GNUPlotPipe gp;
gp.write(“set size square\n set xrange[-2050:2050]\n set yrange[-2050:2050]\n”);
#endif
while (chrono::high_resolution_clock::now() - t1 < chrono::seconds(5)) //run for 5 seconds
//Receive samples
int samplesRead = LMS_RecvStream(&streamId, buffer, sampleCnt, NULL, 1000);
//I and Q samples are interleaved in buffer: IQIQIQ…
printf(“Received %d samples\n”, samplesRead);
INSERT CODE FOR PROCESSING RECEIVED SAMPLES
#ifdef USE_GNU_PLOT
//Plot samples
gp.write(“plot ‘-’ with points\n”);
for (int j = 0; j < samplesRead; ++j)
gp.writef("%i %i\n", buffer[2 * j], buffer[2 * j + 1]);
gp.write(“e\n”);
gp.flush();
#endif
//Stop streaming
LMS_StopStream(&streamId); //stream is stopped but can be started again with LMS_StartStream()
LMS_DestroyStream(device, &streamId); //stream is deallocated and can no longer be used
//Close device
LMS_Close(device);
return 0;
